Codes P0727 & P1775 Mech says unrepairable?
Guest
Posts: n/a
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Mechanic say found problem to be with the harness between the TCM & the ECM and or the engine control module. Talked with a jaguar mechanic this morning he says it's too costly to repair even if I could find a used harness to replace mine & he would not want to do the work anyway. Wow! I am really upset is this a fact, no parts and not worth fixing, this car has been a gem and in great shape first problem ever 138,000 miles and I love it any input would be nice.
SORRY ITS A 1996 XJ6
P0727-Engine speed input signal missing. Meaning engine stalls, key still on, ECM still powered up, looking for that signal.....
P1775-MIL request from TCM. Usually related to stalling.
Causes.
No. 1 Stuck open EGR valve. Probably the most likely candidate.
No. 2 Crank Position Sensor. Commonly replaced for these codes, usually never fixes it.
No. 3 I've seen these codes pop up if the car runs out of gas, overheats, fuel pump fails, or anything that could cause that engine to stall.
The engine harnesses, to my knowledge, aren't available for the X300 anymore. You'd have to search the scrap heap to find one. Or steal it off your buddy's car.
Causes.
Hey Po,
I didn't look at these code, I presume you are sure they are for a six?
Interesting about the fuel pump/ runs out of gas comment, I have never seen or read about DTC's being logged in either scenario for X300/ X308.
I had a no-start on an X300 not too long ago, the ECM had a pin rotted off and the connector was nasty. ECM is deemed as a "non-rebuildable core" in this case, harness hacking as you described would also have been necessary. The guy's car was wrecked, so he didn't want to pay me to get it running.
I thought you guys should know........."P" codes are not manufacture codes they ore OBDII Standard code which means that they never change in description. When a manufacture doesn't use the code in their diag trees it will show up as "undefined code".
I had a few of these where it turned out to be the Transmission selector switch that caused the P1775 code. No data exchange between ECM and TCM because of internal fault in the switch.
30 year "ASE" Master Auto & Master Truck Technician
Thanks for the lesson, I feel so embarrased about all those cars I have sent to the crusher since 1977. If only your guidance had saved me sooner....Nice font too, it looks so authoritative.
I have a proprietary WDS, I read Jaguar factory code descriptions (as opposed to generic P code descriptions) of any DTC's present, and I fix the car. Forgive me for not committing superfluous knowledge to memory.
But it's nice to see we have a new expert, feel free to offer your sage advice to the throngs of people here who need it. You can even do it in CAPS if you want.
Wasn't trying to flap my wings or ruffle any feathers. I started repairing Fiat and Triumph Autos in 1974....there were no scanners and very little Dealer Training Available. I have owned close to 67 cars and 33 Trucks in the 30 years of my life as a mechanic. I was only trying to help. Sorry if I stirred things up. CAPS is like shouting and I never do. May the peace that excells al thought be with you.
I don't read where I questioned your experience, or asked for a resume...I used to dyno test turbocharged Cosworth V8 IndyCar engines with Bobby freakin' Unser yelling in my ear, but it doesn't mean I can fix this guy's Jaguar over the internet. I thought that's what we were talking about.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
I didn't start off on the right foot. New to this whole Forum thing and forgot my place.
Causes.
Causes.
My 1996 XJ6 randomly dies (or sputters) at low speed, or accelerating from a stop. I have spent over $2,000 trying to fix it. New Fuel Pump, lots of short's fixed, still the same problem. It currently has a P1775 code. Haven't checked the EGR valve, or Transmission sensor. Would love some feedback.
Received 2,193 Likes
And lets not forget about the intermittent crank sensor faulure that happens when heated up that burned me on my own xj6 4 years ago. Would just stall after driving and no crank sensor code. When ohmed it out is was fine, until i heated it with a heat gun then it failed, replaced it and "my" car has been fine since. Just to throw that out there for those that have forgotten the issues on these 15 yr old cars
