Cold start valve does not spray
Old 12-19-2022, 06:35 PM
Thatch's Avatar
Default Update. Car starts easily!
Probably nobody cares at this point but hopefully this helps someone else.
I purchased a new cold start valve, Standard Motor CJ33 which is for a 280z I believe.
Installed it and it started up immediately after sitting for 3 days. Never came close to that before. It fits really well just needed to cut a new piece of fuel hose to it which should be done anyway to prevent leaks and fires
I'm hoping my stalling problem is fixed by my new coolant temperature sensor that will be here Wednesday.
In case anyone is listening, I'll update from there
The following 4 users liked this post by Thatch:
2k2JAG (12-20-2022), bullittandy (12-20-2022), Doug (12-19-2022), markdpeter (12-29-2022)
Old 12-19-2022, 09:42 PM
retroren's Avatar
Thatch, oh yeah, at least one person is listening and appreciates your posts. Where did you buy the cold start valve from? Also same question goes for the temp sensor? I'm going to roll the dice and order one of each .
Old 12-19-2022, 09:47 PM
Thatch's Avatar
Default Cold start valve
Thanks. I got the cold start valve in Amazon actually. I think it was $99.
Coolant temperature sensor was also on Amazon. Should be here in a couple days.
When I removed the old dead cold start valve, there was still excellent fuel pressure at the rail after sitting for a few days. The CJ33 fits perfectly.
Old 12-19-2022, 10:05 PM
retroren's Avatar
Thatch, thanks. I might be the only person in America that doesn't buy on Amazon. Did you purchase from a specific seller with a specific part number. I just want to make sure I buy what you bought . Thanks, Ren
Old 12-19-2022, 10:08 PM
Thatch's Avatar
Standard Motor Products CJ33 Cold Start Valve
Standard Motor Products TX107 Coolant Sensor
There were multiple suppliers online. Amazon was just the fastest.
Doug (12-19-2022)
Old 12-19-2022, 10:12 PM
retroren's Avatar
Thanks.
Old 12-22-2022, 07:41 AM
Jose's Avatar
Received 2,462 Likes on 1,851 Posts
I was against Amazon too but after two or three orders I realized eBay is a dead corpse.
Amazon has their own fleet of delivery trucks bypassing all other shippers.
Sometimes Amazon delivers on THE NEXT DAY after you order something. Unbelievable. How can they do that? I don't know.
AND their no-hassle returns? No comparison.
Greg in France (12-22-2022)
  #28
Old 12-28-2022, 08:27 AM
Thatch's Avatar
Default Fuel delivery
I suspect I'm only getting fuel from the driver side tank. Even though there is fuel in the passenger side.
The switch on the dash seems to work as the fuel gauge changes level when I push.
Would this be an issue with the valve in the boot?
Old 12-28-2022, 06:48 PM
Fraser Mitchell's Avatar
Received 2,456 Likes on 1,952 Posts
They can stick and I have had this happen to me coming back off holiday with the boot stuffed to the gunnels with cases, etc. Tank was getting to empty, so I switched tanks and the car died on me. So a quick switch back got us underway, and I parked-up, took all the stuff out of the boot, took the cover off the valve, pressed the tank switch again, then tapped the valve a couple of times with a spanner, and all was well. Yes, it's a PITA !
In your case, the valve not having been operated for so long will have made the thing seize up, so you may need to put in another valve.
  #30
Old 12-28-2022, 06:51 PM
Thatch's Avatar
I figured I'd have to replace the valve. The switch works on the dash to show the level but I don't think it draws fuel out of the passenger tank.
Does this make sense?
  #31
Old 12-29-2022, 05:23 AM
Definite sense. The dash switch swaps over the fuel gauge level transmitter, and also the three valves, (supply in the boot, and two returns, one at the back of each wheel arch)
  #32
Old 12-29-2022, 10:35 PM
retroren's Avatar
Thatch, one small suggestion, consider starting another thread for the gas line issue. You've completed the cold start valve saga and documented it. Thanks to you it's now searchable on it's own. You'll solve your new gas line issue and it would be helpful to search on that separately. Hope I haven't annoyed you. Ren
  #33
Old 12-31-2022, 09:11 PM
Thatch's Avatar
Default Misfire
I have replaced the entire fuel and ignition systems in this car, except for replacing the entire distributor itself (new cap) New coolant temperature sensor
Drained tanks, checked compression and fuel pressure all look good.
The car starts and runs reliably but feels like I have misfire. I can feel it at idle and upon acceleration there is always a slight shudder and just doesn't feel like all the power is there.
Anyone have any ideas? I was thinking valve adjustment but this is not an easy job on this car
  #34
Old 01-01-2023, 05:42 AM
Jose's Avatar
guesswork ideas:
1) a bad spark plug
2) a bad spark plug wire
3) if the car is older than 1986, add a ground strap from Oxygen Sensor to body of car.
  #35
Old 01-01-2023, 07:05 AM
Thatch's Avatar
Thanks for the reply.
The plugs and wires are new.
What is the procedure for adding the ground strap?
Does it attach directly to the body of the O2 sensor?
Please give some details. I've not heard of this before
Happy New Year!
  #36
Old 01-01-2023, 07:40 AM
Jose's Avatar
Please give some details. I've not heard of this before. Happy New Year!
Even new spark plugs fail, check each one and each wire.
I have details in my website for a O2 sensor ground strap. I resolved an intermittent misfire in my 1984 by adding a ground strap to the O2 sensor.
Jaguar added a ground wire to the sensor starting in 1986, so this may only work in pre-1986 4.2 fuel injected engines with 1-wire sensors. If your sensor has 2 wires from the sensor, you don't need this.
Otherwise check in my website:
https://jagupgrades.webstarts.com
  #37
Old 01-01-2023, 08:26 AM
Doug's Avatar
Received 10,944 Likes on 7,190 Posts
Good tip from Jose. And adding the O2 sensor ground is a good idea on general principle, even if your not fighting a specific problem.
And it can be helpful even on the post-85 cars. A bit of history on the matter....
The cars thru 1986 originally came with one-wire sensors. A lot of the cars were failing emissions tests and it was traced to poor O2 sensor performance. Specifically, the sensors were not heating up fast enough. What Jaguar did was to use a heated O2 sensor. These sensors had three wires: signal to the ECU, 12v "+" to the heater, and ground to the heater.
The ground was was just for the heater circuit. The signal circuit of the sensor still used the not-always-reliable surface grounding. Therefore, even if you have the later three wire sensor, adding a sensor ground as described can be helpful.
California registered 1986 XJ6s were subject to a recall for this matter and Jaguar made a parts kit to retrofit the three wire sensors.
The heated three-wire sensors were standard issue for USA 1987 cars but since "model year" designations vary from country-to-country the easiest way to tell if your car originally had the heated sesnor is to simply look at the dashboard. The oxygen sensor warning light was used only on cars with the non-heated, one-wire sensors. The warning light was not installed on cars with the heated three-wire sensors.
  #38
Old 01-01-2023, 10:44 AM
Jose's Avatar
Great tips Doug. I was not aware adding a ground strap to post 1986 sensors was also a good idea, so I will update the description in my website.
I have sold many of the straps I build, but I never hear back from any buyer, which might be a good thing !
Back in the late 1980's and early 1990's this O2 sensor ground strap was put down as "snake oil" by a number of posters at JagLovers. Remember? But since it came recommended by the Motorcars Ltd. factory-trained technician whom I'm sure you remember, I ignored them and went ahead with adding a ground strap properly made. My engine idling became stable and "reassuring". Still runs like that today.
So Happy New Year and thanks for the support.
  #39
Old 01-07-2023, 11:49 AM
Thatch's Avatar
Default Problem solved
One of my spark plugs was black. I replaced the fuel injector with a brand new one and now car runs perfect.
Actually has some power. It's been a long road. Now working on interior and the blower motor issues
The following 2 users liked this post by Thatch:
Doug (01-07-2023), Greg in France (01-07-2023)
James O
12-19-2022 10:01 PM
ahunt4
01-24-2015 05:45 PM
edobernig
General Tech Help
08-11-2012 09:48 AM
skanoski
05-11-2008 12:32 PM
jagon
XJ40 ( XJ81 )
01-15-2008 01:26 AM
Quick Reply: Cold start valve does not spray
