cold starting
Received 10,978 Likes
Cold start injector.....
....which is controlled by the Thermotime Switch
Cold Start Circuit Checklist, Jaguar XJ6 Series III
I am confused on this. Can someone please help me out? I am going thru this test Cold Start Circuit Checklist, Jaguar XJ6 Series III and #2 is the starter relay. Where is this at? and #3 is the cold start injector between the middle two intake runners runners. not understanding this!!! the only thing I can make out is the extra air valve, but removing the fuel supply hose is in no way in the way. does someone have pictures or a diagram of some type that I can refer to? Thank you so much for any help I can get.
Here you go. Found this searching under "cold start injector" in literally 30 seconds…
https://www.jaguarforums.com/forum/x...-valve-164680/
Regards,
Andrew.
Regards,
Andrew.
amaezing (07-26-2016)
