Common oil leaks???????
Old 06-25-2016, 01:43 AM
Rickxj6's Avatar
Default Common oil leaks???????
I have a slight oil drip coming form somewhere under the centre front of the engine but without pulling stuff apart can't quite locate where exactly it is coming from.
Are there any common things that i should be looking for first?
Old 06-25-2016, 04:01 AM
Received 10,468 Likes on 6,913 Posts
OH boy.
Front suspects:
Timing cover seal
Vent cover on the front of the head, oil runs down.
Sump gasket (rare in the big scheme).
The joint between the timing cover and the cylinder head. The seal is the head gasket, BUT, if that cover has been off with the head in place, resealing that gap is a mongrel.
Many more areas for leaks, but NOT at the front that I can remember.
Rickxj6 (06-25-2016)
Old 06-29-2016, 04:05 PM
Dr Phill's Avatar
Give it a good wash down then take it for a drive. Re-inspect, so much easier than guessing. It seems front crank seals are common.
Grant Francis (06-30-2016)
Old 06-30-2016, 12:58 AM
Rickxj6's Avatar
Found 3 so far. Rear of valve cover, front of other valve cover & vent cover. was going to to have another go at it this weekend but it is getting painted instead.
Old 07-07-2016, 06:56 PM
Richard_gib's Avatar
mine was a perished 'o' ring in where the oil cooler pipes join into the oil filter block head assembly thingy. cheap part, BI*CH of a thing to get to and change :-)
My leak was more of a dribble than a drip, and it only happened when the engine was running.
aholbro1
02-14-2021 01:51 PM
Amelorn
04-16-2016 07:46 PM
mrplow58
04-11-2016 04:19 PM
Mrqng78
04-06-2016 11:49 AM
Dean Kitching
03-30-2016 02:53 PM
Quick Reply: Common oil leaks???????
