Compresion test
Hi,
i have performed a compresion test. With, wires disconected, i have measured each cylinder. The readings were between 105 and 115 psi. The good news is that they are close. The bad news is that I do not know what 110 psi means. It is low, it is ok?
What should the compresion be?
Received 10,906 Likes
Probably should be in the 150-160 range.
If the engine runs well wouldn't worry about it. The engine may well soldier on for a long time in with low compression...although horsepower will be down a bit. I suspect your low-ish numbers are simply the result of normal wear; worn rings most likely. A leak-down test would confirm where your compression is going
Simple test to see if there is excessive wear.
You state that all the readings are close, this is a good sign, they should be within 10% of high to low.
With all the spark plugs out and a good battery, place about one teaspoon of engine oil in each cylinder before doing a repeat compression test. Once again the increase in compression should not exceed 10%, if it does the rings are worn.
Totally agree with others in that you may indeed get quite a few more miles out of the engine before a major overhaul is necessary.
Be sure to keep an eye on the oil pressure as well. Low oil pressure would indicate bearing failure is immanent.
The Moneypit
05-02-2018 09:37 AM
cyber3d
06-28-2015 09:06 PM
