Converted 1987 XJ12 high front suspention
Hi, all. While searched, I am sure I am missing some forum threads on this-- has to be more common than I.
Last year I acquired a converted XJ12; has a Chev or GM small block The front end sits higher as a result of the lighter weight of the transplanted engine.
At this time, I do not see a need to replace the existing engine, so I am basing my suspension needs on the current state. How might I best go about a solution for correcting the upward tilt?
I have heard of people modifying existing or sourcing alternate springs to accommodate, others indicating that custom springs are the correct way to go.
Thoughts from experienced folks on this?
Both 6 cylinder and the 12 cylinder are much heavier than the small block Chevy. More so if you've got an aluminum intake and heads. Your best bet is to Source a set of xjs 6 cylinder front Springs this is the car or the xjs that came with the AJ 6 or aj16 engine. If you can find a set of those Springs you will only need to add 1/4 inch spacer to the lower spring plates for the correct ride height. If you have an all Iron small block Chevy you can probably get away with the xj6 springs and use spacers on the lower spring plate to get the right ride height. The V12 Springs there is no hope they will need to be changed for a small block Chevy they are just too stiff and there is about a 400 pound difference between the two engines more if you've used aluminum parts
Received 2,399 Likes
Robert;
If that spell failure is the worst thing you have or will do, life is fine.
Two fixes:
1. Swap in springs from an I6 powered car.
2. Add spacers between the lower control arms and the spring pads.
My car is a LUMP. As it came to me, I6 powered, the "nose down" stance was pleasing.
Out with the ailing six, and in with the much lighter LT1, and the nose came to spec.
I like it that way, a whole lot !!
Check with Jaguar Specialties or David Boger @ everydayxj for the fix.
Carl
Carl
Two fixes:
Carl
Carl
I found Broken Kitty (John's cars) to have mention of such. That they fabricate springs for the conversion, but information on the website is not too clear and the email address available there bounced back on me.
Johns cars have never been much as to email. FAX and phone, preferably the latter, has worked for me.
I don't think they have the capability of making coil springs. But, are very clever in finding sources and stocking stuff.
I used their kit to do my LT! into 83 XJ. The documents mentioned the V8 in lieu of V12 issue. Solution at the time was, use springs from an I6 powered car.
There is a company in Illinois, I think. Eaton Spring ... They can probably wind up a pair, but for more than a few $'s.
Or, get a good used pair from David Boger at everydayxj. Good guy and posts here.
Always a big help.
Carl
Always a big help.
Carl
I found it but unfortunately i dont know if they will fit your car.
https://www.sparesbox.com.au/car-springs
part number: 9992-KJFL-05
Fitment: Front, With Chevrolet 350 Motor; When Fitting Jaguar XJ
I hope it is of help to you, or at least maybe to anyone else looking
Robert Leonardo (05-13-2017)
