coolant temp sensor
Received 10,978 Likes
the wiring looks good from what I can see
but I checked the plug and with the key off I get good ground from both wires but with the key on I get ground from the black supply wire but I get power from the blue orange wire witch is the return wire, I'm guessing there shouldn't be power there.
I'll have to mull that for a minute
could it be the computer?
It's just that ECU/computer failures are a bit unusual so most of us are reluctant to go there until all other choices have been checked and eliminated to the greatest extent possible/practical. Low demand means used units are reasonably priced, though, so replacing as guess is not too painful.
Yes.
Yes.
do you know where the computer is, I think I saw somewhere its in the trunk behind the rear seat
My gut feeling is that you are correct...but I'm just not sure. With the engine running things might change. others will chime in.
For example, your fuel injectors will show "+" voltage/power on both wires with the key on. But with the engine running the ECU grounds one of the wires to fire the injector. That wire then returns to "+" voltage. These are nano-second events, as you might expect.
wde86 (05-20-2016)
thanks, I'm going to order a computer Monday if no one else has any ideas
I found one for $80 close to me so it shouldn't take long to get
Clamp the cold start injector's fuel line. Any change? Stuck open or leaky CSV.
Has your air flow meter had its top popped off?
Have you looked at the aux air valve? May be plugged up inside.
Hmmmm
Hmmmm
#28
the top is off and I adjusted it but it made no difference
where is the aux air valve? I will check that out
Which suggests there is no electrical malfunction. However it could still be stuck open, hence the idea of clamping it off
Bolted to the underside of the water rail....funny looking aluminum casting
#30
That is highly suspect. No adjustment will improve the AFM and any existing alterations from a PO are almost impossible to undo. Swap with a known good unit is the only practical option for confirming proper function.
#32
Anything that affects the air/fuel mix is suspect.
I think you have inadequate air to burn the additional fuel when cold. And that is more likely the AAV not flowing air when cold, but it could be contributions from multiple slightly off-spec components as well.
#33
I'd try a known good AFm and, if no joy, go right back to square one, methodically checking ignition system, all fuel injection relays and connections, grounds, etc.
As for the AAV, FWIW, once I drove a Series III for about a month with the AAV removed from the car and the hoses plugged. It ran fine. The only hitch was an occasional stall at idle after a cold start...ambient temps in the 35ºf - 40ºf range.
Letting the engine warm up for about a minute with the throttle held to about 1200 rpm took care of that.
#35
You'll have to remove it from the water rail so you can look inside the air passage. There's a disc in there that rotates to increase/decrease the amount of air passing thru. More air when cold, less when hot.
Removal is a little tricky as one of the AAV hoses is under the intake manifold. But, the hoses need to be check anyway, right?
#36
There's no convenient way
right, I'm going to tare that off as soon as I get a chance
thanks
#37
I got it removed, I'm not sure if I broke the hose getting it off or not but either way its brittle and needs to be replaced, how do you get to the other end of the hose, do I need to remove the intake?
I can move the wheel in the aav with a screwdriver, do I just hook power up to the plug to see if its working?
#38
Lord no ! That's a huge job.
You gotta get under the car....in just the right position....and you'll see where to disconnect it.
The hoses is a different diameter at each end as I recall. You'll need to order one from a Jag supplier
I can't remember offhand what powers up the internal heater. Not sure if simply turning the key 'on' will do the trick, or if if gets voltage from the fuel pump circuit, or what. Others will chime in.
#39
Looks like voltage comes from the white/green wire of the fuel pump relay. Ground comes from the ECU on the white/pink wire.
You could rig up a bench test easily enough
#40
I put it in the freezer and if it moved it was a minimal amount, I'm guessing it should open up pretty much all the way
with power it did nothing so I'm guessing its bad
