Coolant temperture
Received 10,990 Likes
From an old J-L posting
First column is temp in ēC and second column is ohms
55 255
60 210
65 177
70 150
75 128
80 110
85 92
90 73
95 62
100 55
I wish I was 100% positive about this info but I'm not, sorry.
If your test results are similar to above then the info is probably correct. If you have wildly different results I wouldn't condemn the sender predicated only on what I wrote above!
55 255
60 210
65 177
70 150
75 128
80 110
85 92
90 73
95 62
100 55
Have an issue, but cannot figure out how to manage a new post: 2003 S type 4.2..temperature gauge goes off to cold... limp mode engages... no overheating... turn car off wait a few minutes... problem goes away ( guage works fine)...gauge appears to not be working for that time period... any thoughts on this one.. thanks wordman
Received 2,399 Likes
Or another means to measure coolant temperature and compare numbers.
An IFR gun from HF for just a few bucks. Read at about the same place as the sender and compare.
Might even find an old capillary guage and plumb it in in lieu of the Jagensor and see what numbers it comes up with!!
Carl
Carl
Carl
Carl
X308XJR
05-20-2019 06:50 PM
