Coolant warning light - RESOLVED
Now that the fuel pump circuit is fixed, and the car starts right up, I'm starting the process of investigating why the a coolant warning light on the dash has tripped on in my 85 xj6.
Currently: I have coolant in the reservoir, and am assuming (hoping, really) that this is an electrical lead problem.
I've read the helpful post here: https://www.jaguarforums.com/forum/x...t-light-56901/ but did have a few 'what next' questions:
First off, is there any way to test the coolant sensor?
Second: How about the transmitter under the dash (any way to give it a signal it should interpret as 'okay' so I can see if the light goes off)?
if you pull/pry the indicator lights faceplate, (the black plastic plate between the speedo and tacho), there are spare bulbs there, because some idiot lights are not used in the Series 3, 6-cylinder XJ. just pull the plate with your fingernails.
OkieTim
09-08-2015 04:48 PM
