Correct tires for my 1987 XJ6
Received 10,916 Likes
I believe you meant to say "...as fast as a V rated tire will go.....".
I don't know of any tire manufacturer that publishes sidewall specs but we assume...probably correctly...that tire with a higher speed rating and/or higher load rating will have stronger sidewalls.
Since V-rated (o even H-rated) 215/70x15 tire are almost extinct we're left with looking at highest possible load ratings. If you can find that size with a 98-99-100 load rating you'll probably be getting the stronger sidewall you're looking for.
Tire Rack is one good place to start the search
wnlewis (11-09-2014)
Gatsby
09-06-2015 11:52 AM
