Cylinder Thing
Its an Ignition Coil.
Usually bolted to the side of the engine, close by the distributor (mostly), and if its Lucas brand, a paper weight makes a good alternative use, and probably significantly more reliable doing that, as compared to what it was originally design to do.
It provides the High Voltage spark for the spark plugs, which in turn ignites the fuel/air mixture and gives birth to the internal combustion engine.
Not sure of the "Sports" connotation, being Lucas and all that.
Dickie_L_J_O
09-13-2015 07:44 AM
