Delanair 2 evap and heater matrix
I see evidence of a coolant leak at one of the heater matrix tubes-crusty deposits on the stuff below it. I am visualizing a new heater core and probably A/C evaporator while I'm in there. I am having zero luck finding a new evaporator. Amazon shows a Four Seasons unit but doesn't give a vendor and the Four Seasons website has zero listing for my car-not even the part # given by Amazon.
Do any of you folks have any ideas of where I might find the evaporator and heater core? Thanks.
Dave
Dave
Received 10,920 Likes
The following 2 users liked this post by Doug:
Grant Francis (03-29-2020),
Greg in France (03-29-2020)
Thanks for those two numbers, I checked every one and found a heater core at etypeparts.com but no one had an evaporator, either "no longer available" or "special order" or none in stock. I guess I'll just see what I've got when I pull them out. The only reason I mentioned replacing the evaporator came from a how-to post on J-L where he felt that one should just replace the evaporator as a matter of course while you are in there replacing the heater core. I have never had an evap go bad in any car/truck I've ever had, is there a particular reason I should replace one in a Jaguar if there is no evidence of leaks?
There hasn't been any coolant or refrigerant in either system for 15 years, if I turn down my air pressure to, say 10lbs, could I pressurize each core and use a little soap/water to look for leaks?
Dave
Dave
Thanks for the web addresses Greg. I checked "techchoiceparts" and they say it's discontinued. "Justjagsuk" says ".....ETA unknow, call for more information". I found the heater core for a good price and that's what is leaking. If the evaporator doesn't show signs of leaking with a little air pressure on it, I'm not inclined to replace it.
I'm going to add those two web site to my very long bookmark list for future use. Thanks for your time.
Dave
Dave
Greg in France (03-30-2020)
There's no reason for the evaporator to start leaking, as it doesn't get exposed to any corrosive medium, unlike the condenser at the front of the car, which tends to get a lot of water and salty water thrown at it. So condenser replacements are fairly common, not so the evaporators. As for the heater matrix, this is best replaced
https://www.sngbarratt.com/English/#...ITIONING(16230)
Evaporator is expensive, and you'd have to wait.
It's comforting to hear your assessment on the evaporator, they appear to be very expensive if I could find one. With a new heater core on the way, I will take the Delanair unit out and look everything over. I've read that the foam/rubber seals in various places deteriorate and should be replaced. I'm familiar with the process.
Thanks for your input Fraser,
Dave
Dave
Doug (03-31-2020)
Lawrence Watkins
12-10-2022 08:52 AM
Corndonkey
22
12-11-2020 03:42 PM
Lawrence Watkins
08-05-2019 07:26 AM
