Diff question
Received 9,218 Likes
Received 10,874 Likes
The usual Jag ratios for the older diffs are 2.88 3.07 3.31 3.54 3.77 4.09
Other possibilities are out there as the diff is apparently a kissin' cousin to the well known Dana 44.
I would contact Icsamerica as he has a good handle on this subject
There's some info in this thread that might help
https://www.jaguarforums.com/forum/x...f-head-123057/
Since you're racing I'd avoid the thick gear science project. The best thing to do is purchase a new 19 spline Auburn locker, Dana 44 gear set, Dana 44 side bearings. Then install a standard dana 44 yoke and matching drive shaft, this can get you any Dana 44 ratio you want and you'll have a modern system for solid launches.
You'll also need to manage cage roll. The rear IRS will rotate and cause wheel hop / Axle tramp and loss of traction when approximately 350HP is applied.
https://www.jaguarforums.com/forum/x...shings-119418/
The largest rear tire you can fit in the rear wheel well with clearance is a 235 series. That's not enough for a hard launch with a tall diff. A larger tire can be fitted but flaring the rear wheel well is required.
Received 1,236 Likes
mount it solid to the car(no rubber mounts), makes for a rough ride and hear all types of road noise, but if its a race car be alright!
there are stories about the actual cage twisting ,and the outer aluminum hubs cracking.
Jag type rear suspension was never designed for hard accelleration with hi-grip tyres.
