Different Fuel Rails - Series 3
Hello,
After receiving a new fuel pressure regulator for my 1983 XJ6, I quickly realized I didn't have the right part... Instead of all three fittings (2 fuel + 1 vacuum) be a beaded hose fitting... instead one of the fuel fittings was threaded. Upon closer inspection, it looks like some cars were fitted with a straight fuel rail that is compatible with the threaded fitting (color image below) and those with a circular style that require all barb fittings (b/w image below).
Question... anyone know why the deviation exists?
Thanks!
Nick
Thanks!
Nick
ukborn (01-06-2024)
The following 3 users liked this post by Jag-o-nomic:
The earlier fuel rail that I had on my 1980 was an absolute PITA, as it was very prone to leaking where the flexible pipes joined it. In addition, I understand the later one is less prone to fuel vaporisation due to heat. The later fuel rail is a lot better, so if you can, swap them over.
Naber (02-10-2021)
Thank you for the quick and helpful reply! I thought I was going crazy... and given the later is more preferable, it gives further evidence that the XJ6 I purchased is extremely original. thanks again.
