Differential for 1987 S3
I need to remove the differential in an original owners 87 S3 with 152k miles. The car is located in north Florida. The diff is leaking bad from pinion and output shaft seals and I have no intention of just installing new seals in it and calling it a day. I need to get it rebuilt but I have no clue who would even be able to rebuild it. I know that as the death clock marches on, fewer and fewer people have actually worked on these cars. I would feel way more comfortable shipping it somewhere in the USA that actually knows what to do rather than blindly letting someone rebuild it locally. I have driven the car and there is no gear or bearing noise but, it’s way too much work to R&R it and find out the bearings have too much play and still leaks oil even with new seals. I want to ‘one and done’ with the diff replacement.
Does anybody have either a trusting source to rebuild a diff or know where I can buy a rebuilt diff from? Please and thank you for your time.
Received 10,870 Likes
The following 2 users liked this post by Doug:
Addicted2boost (09-24-2023),
LT1 jaguar (09-23-2023)
The following 2 users liked this post by Darrenmb:
Addicted2boost (09-26-2023),
slofut (09-30-2023)
I supplied everything as I was originally going to do it myself, but being as I was changing to an auburn limited slip, nothing was stock, but everything was available off the shelf, when I was calling around ( to find someone that would do the rebuild with my parts) ( I was just asking about rebuilding a jag irs diff) nobody has any issues or was worried about instructions, then place I ended up using charged me 400
Doug (09-30-2023)
Gilxj695
07-27-2023 07:28 PM
