differential fluid change ???
Guest
Posts: n/a
> Hi,
> I have a 1996 jaguar xj6 and wish to change the differential fluid,so I
> got royal purple fluid to change too. I took it down to the local lube
> place and they looked and could not find how to refill once it was drained,
> and said they thought that there was more then one drain plug. Well I
> found that you refill it through the truck and only see one drain plug.
> Now is there more then one drain plug?? and can I use a funnel and
> section of hose to refill the system or do I have to buy the kit to
> refill it from Jaguar???
> Thank You for help
> Frank
Received 10,871 Likes
When I first acquired my car (86 XJ6) a couple months ago, I crawled under it to examine the differential. The fill plug is exactly where Doug stated it is. It takes a contortionist to reach up there and unscrew the plug (which has a square end on it). I was able to do it by reaching up over the rear end with my left hand and using a small adjustable wrench. Slowly, I turned the plug a couple threads at at time until it came out. The first turn was difficult because it had not been taken off in eons. Once it was off, I dipped my finger in the hole to check the level of fluid. It was right up to the bottom of the fill plug. Cleaned up the threads, put some anti-seize on it and put it back on. I will be changing the fluid once I get it on a friends lift. That will make the job much easier.
A general rule of thumb... never take off the drain plug of a differential, transfer case, etc unless you are certain you get the fill plug off first. That way you are not left with one that is empty and renders the car unusable.
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
