Diodes & Relays Oh My
Old 08-16-2016, 09:59 PM
adenshillito's Avatar
Default Diodes & Relays Oh My
my horn relay is pretty plain but noticed on a wrecked 1979 Series 2 that it had a additional diode (which I thought was a lighting thing normally) latched in via green wire then on to the main cables.
see images. just curious if anyone knows why?
from the 79 model Series 2
from my 1974 series 2
Old 08-16-2016, 11:05 PM
Doug's Avatar
Received 10,872 Likes on 7,151 Posts
The red one looks like it might be a cooling fan relay.
A horn relay wouldn't typically need a diode but cooling fan circuits often have one
adenshillito (08-16-2016)
Old 08-16-2016, 11:43 PM
as it was located close to the fan/radiator that sounds about right then.
just seemed odd when i first saw it and couldn't figure.
Old 08-17-2016, 03:51 AM
Received 6,327 Likes on 4,370 Posts
The diode sends power to the fans when the air con is turned on, it over rides the water temp sender that turns on the fans therefore when the air con is on the fans run all the time.(in my case anyway) And it stops the fans feeding 12 volts back to the compressor when the fans are activated by the water temp sender.
Basic explanation I know, but it makes sense to me.
adenshillito (08-21-2016)
Old 08-17-2016, 06:59 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Diodes, interesting little guys. A one way valve for volts, so to speak.
So, an e fan is a SD motor. Reverse the rotation and it becomes a generator!!! So, if the air flow causes the fan blades to turn in reverse, volts are created and flow to where they might not be wanted. A version of 'back feed". I knw enough about electriclkery to confuse myself...
A pair are built into the load legs of my lump's starter relay, Not sure why, but their absence can wreak havoc.... don't ask...
Carl
Carl
zarnca
09-07-2023 12:48 PM
jacquesblom
08-19-2016 03:05 PM
Undertaker
08-07-2016 03:23 PM
Wolfy
08-01-2016 01:15 PM
baudrate
07-24-2016 03:04 PM
Quick Reply: Diodes & Relays Oh My
