Do Not Slam Boot Sticker
Old 09-04-2016, 06:13 AM
Jag-o-nomic's Avatar
Default Do Not Slam Boot Sticker
Hi Everyone,
A little while back, I came across an original issue Do Not Slam boot decal.
Mine was long gone, just like most of yours I bet, with just the residue of the adhesive left on the plastic plinth.
A couple of weeks back, I had the new old stock one scanned and had a vinyl one cut to the original shape.
Not a cheap exercise, but very satisfying since I fitted it this afternoon.
Just a reminder, press your boot (trunk) lid gently, don't slam!!
Cheers,
Nigel
Attached Thumbnails Do Not Slam Boot Sticker-jag-boot-no-slam-sticker-marked.jpg
The following 3 users liked this post by Jag-o-nomic:
Daf11e (09-04-2016), littlelic69 (09-08-2016), ronbros (09-07-2016)
Old 09-04-2016, 09:15 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Slick. I wonder if a transparent sheet in the printer would do that?
A fellow lister on J-L made a "lens" for the needed "Check Engine" light in my swap. It replaced the O2 counter in my fascia so nicely.
Further thinking, I wonder if vinyl is available for home style printers???
Succombed to Garage sale temptation. An additional printer. A Canon, this time. A bit newer than my ancient and more ancient Epsons!! Ugh, no ink cartridges. And a slightly larger monitor for the spare Dell. My "experienced" eyes will like that.
7" for 5 1/4" lamp project moves along. Bench full of components. Two buckets clean and painted. Now, match in adjustment and secure hardware. And spare bezels to grind to fit 7's.
Toys, will I ever....
Carl
Old 09-04-2016, 01:39 PM
sov211's Avatar
Received 2,306 Likes on 1,389 Posts
Originally Posted by Jag-o-nomic
Hi Everyone,
Cheers,
Nigel
Nigel: the following is not a criticism, but a comment. Either the "NOS" sticker was a mess or the scanner was having a bad day. Virtually everything on the left hand side is nonsensical and much of the right side as well.
I do have several CORRECT Series III stickers because I had them properly reproduced from a 1992 Series III sticker when I was doing restorations. PM me if you want one - but again, what you have now is simply wrong in every way. And you are right - these stickers are the finishing touch so they should be correct.
Old 09-04-2016, 04:34 PM
jagent's Avatar
Nice one Nigel, looks great. I never knew they were fitted in the first place, if so all traces of mine are gone!
Old 09-04-2016, 04:38 PM
jagent's Avatar
Originally Posted by sov211
..Virtually everything on the left hand side is nonsensical and much of the right side as well...
Why nonsensical? The sticker simply displays the message in several languages.
Nigel, are the smudges in the photo or were they on the sticker before scanning?
Old 09-04-2016, 05:01 PM
Default Fuzzy Logic
There was some flash flare in the photo, so I used the in app control to try and fix it.
I definitely fixed it, as the affected area looks a bit funny.
Trust me, the sticker is clean and crisp and looks just right.
Tony, I have one spare (just in case I made a meal of fitting it), so I'll keep it for you.
Cheers,
Nigel
jagent (09-04-2016)
Old 09-04-2016, 05:38 PM
jagent's Avatar
...Tony, I have one spare (just in case I made a meal of fitting it), so I'll keep it for you.
Cheers,
Nigel
Thanks Nigel, that would be great! I'll pm you.
Old 09-04-2016, 06:00 PM
anjum's Avatar
Cheers,
Nigel
Nice work.
Would this be the same as the series 2?
Any chance of sending me the scan file, if I pm you my email or is there a section somewhere we can post files?
Old 09-05-2016, 01:48 AM
Hi Anjum,
Nigel Thorley indicates that the sticker was the same across Series 1-3.
The art file I was given was some exotic Illustrator (?) file which I could not for the life of me open up as I am not in graphics and design.
Needless to say, I discarded said file as it wasn't doing anything for me, sorry.
Cheers,
Nigel
Old 09-05-2016, 07:57 AM
anjum's Avatar
No problems.
I'm a long way from needing any stickers yet!!
Old 09-05-2016, 11:35 AM
sov211's Avatar
Well, "nonsensical" because none of it is correct Italian, Spanish, German, or French - unless there is a problem with the photo.
Please see the attached photos I have just taken of the stickers I have; these are exact copies of the stickers from the very last Series III cars (1992) - and identical in wording to every sticker used on the Series I to Series III cars.
The English reads: DO NOT SLAM - PRESS GENTLY TO CLOSE
The French reads: NE PAS CLAQUER - APPUYER DOUCEMENT POUR FERMER
the German: NICHT ZUSCHLAGEN LEICHT DRÜCKEN ZUM SCHLIESSEN (and the missing hyphen after the first words is a correct error - in other words, it should be there but was a factory print error).
the Spanish: NO CERRAR DE GOLPE - OPRIMIR SUAVEMENTE PARA CERRAR
the Italian: NON SBATACCHIARE - PREMERE DOLCEMENTE PER CHIUDERE
Compare this with Nigel´s copy. Unless the photo of Nigel´s copy is compromised in some way, I repeat that the copy is not correct.
Attached Thumbnails Do Not Slam Boot Sticker-do-not-slam-1-002-small-.jpg   Do Not Slam Boot Sticker-do-not-slam-1-001-small-.jpg
Old 09-05-2016, 05:16 PM
Photo of new sticker in place without flash flare
bill70j (09-06-2016), Daf11e (09-06-2016), jagent (09-06-2016)
Old 09-06-2016, 12:52 PM
sov211's Avatar
Right! amazing...so it was a photo-failure ("flare") that messed up the print in your first photo - a mystery to me but obviously your reproduction is just fine. I retract my comments. Your sticker looks perfectly correct in this photo.
Old 09-07-2016, 03:37 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
Hi Everyone,
Cheers,
Nigel
i NEVER let anyone close my trunk/boot, just a light down push and it clicks!
Old 01-14-2017, 06:57 PM
jag_sticker's Avatar
I reproduced both styles of Do Not Slam sticker a few years ago. There were two styles of drawing and different fonts used. These were profrssionally printed on high tack vinyl and designed to last longer than the originals. I still have a few remaining..if anybody wants one then please message me. Also have lots of other XJS decals.
As we as being used on the XJs they were also used for Rover P6s.
Regards
Old 03-27-2017, 11:39 AM
yachtmanbuttson's Avatar
Just found this old post. Am restoring my 1975 XJ6C and need a DO NOT SLAM sticker. Do you still have one?
Thanks, Bill
Old 03-28-2017, 12:40 AM
Hi Bill,
Good luck with your restoration.
I have a couple of stickers left.
Give me your zip code and I can get a postage price for you.
Cheers,
Nigel
Old 03-28-2017, 07:08 AM
Great! Thanks. 34997 Stuart, Florida
Old 03-28-2017, 08:34 AM
JagCad's Avatar
Whew, now, I gotta look. However, if it is missing, I'll not panic !!! Other fish to fry, lots of 'em !!!
1. Daughter's stuttering Passat.
2. No run Jeep.
3. Jungle in lieu of garden.
4. Incomplete major prune of Hawthorne tree.
5. Tax time.
Carl
Old 03-28-2017, 04:42 PM
Thanks, Bill
Sounds like Jag-o-nomic has it covered.
Don't forget there are two designs of decal for the boot decal...the second type introduced about 1981/2. There's not much difference - slightly altered drawing of the hand/arm and smaller text of the later version.
I have 2 of the early types and 4 of the later types left in stock.
Regards
David
Quick Reply: Do Not Slam Boot Sticker
