Door Keys
Interestingly my ignition key also works on the door lock, however I think it's due to a worn door lock that would probably accept any key put into it!
The fuel filler caps also have a different key to the door & trunk, hopefully yours are unlocked! I didn't have this key, but they were unlocked so I had a locksmith change the lock tumblers to fit the door key. Worth doing at some point so you end up with one key for all locks in addition to your ignition key.
