Door Lock XJ6 Series 1-2
The left side door lock will not open from the outside by pushing the button.. Removed door card to find that the linkage works fine but won't push the pin up far enough to release the latch. All lubricated and working freely. Any experience with this ? Will add photos shortly !
Looking forward to the photos in the hope I can help - not something I have seen often. Most commonly was on S2 coupe's with doors that had dropped and were sitting on the lock strikers. Other times, the grease /lubricant had baked so hard inside the plastic latch housing on the door that the mechanism couldn't move. Soaked to soften and remove and re-greased recovered functionality... just some thoughts...
Allyn.
Allyn.
77 XJ6C
Yes, It is a coupe but door sag and alignment does not seem to be the issue. What I do see however is slop in the linkage when the button is pushed. Not sure if it is enough, but seems likely. Excuse the 40 plus years of dirt, but doesn't seem to be the problem. When I say Locked here I mean door closed and Unlocked Door Open. Next Reply shows Door actually "LOCKED" where mechanism moves the tab out from under the pin so no lift can occur.
What kind of video can we load if any ?
Pin in locked position
Last edited by Excalibur2012; 01-23-2021 at 11:40 AM. Reason: Clarification ..Maybe !
Test to eliminate tab wear.
I recall once needing to eliminate tab wear as the cause. The quick in situ test we did was to use a short piece of clear plastic tubing (such as used in the windscreen washer circuit or in aquariums) and slippd it over the pin to "fatten" it temporarily for the test. Once this was installed, the lock mechanism did function. Because it was in the days where a multitude of parts were easily obtainable, at the owner's request we simply fitted a new unit. Problem solved. The down-side is that there was no further investigations done as to why there was accelerated wear on the tab... sorry that probably isn't much use to you...
Received 9,472 Likes
This happened once on my Series 2, and I had to adjust the rods from the inside with the door closed in order to make it work properly again. I haven't had trouble since.
https://www.jaguarforums.com/forum/x...2/#post1618794
GGG (01-26-2021)
XJ6C Door Latch Issue
Was able to spend time cleaning up the mechanism and working on a solution. I can say I do not believe "Tab Wear" is a real issue. The tab is only about 1/16 Inch in thickness to begin with. I believe if there is wear, it is in the small plastic bushings or elsewhere in the linkage. I placed a piece of tubing over the pin, bent the tab upward slightly and the latch is now operating by pushing the button from the outside. I imagine an overhaul of the linkage is in order, but in the meantime, I may also install a clip on the tab to make it thicker.
The following 2 users liked this post by Excalibur2012:
Greg in France (01-29-2021),
LnrB (01-29-2021)
Greg in France (02-10-2021)
XJ6C Door Latching
That would of course be a great option, but the problem actually looks like a failed 2 Pence plastic bushing on the lift rod. No joy in just replacing the entire unit.
