Door-to-window seal replacement
I replaced the one on my driver's door recently. It was dry and cracked. I bought the replacement from rockauto:
https://www.rockauto.com/catalog/mor...789&cc=1178074
It says you need 2 per door, but that's incorrect. I purchased two and one is long enough to do a single door, front or back.
I took the door card off, put the window down, then used needle nose pliers to slide and pull the old strip/beltline out. The lower edge of this beltline has a channel that holds it in place. Then I sprayed some silicone spray on the new strip and slid it into place. Little tedious, but didn't take long.
NathanDD6 (11-12-2015)
Exactly, thanks. I've heard them called door cards, inner door panels. Jaguar's official name is door casing, item 3 in the photo.
The rubber/felt strip that rubs against the outside of the window is item 5, Door Waist Seal, part BD464586. I was happy with the URO part I received from Rockauto.
![](http://www.jaguarclassicparts.com/illustrations/images/mv8321.png)
Door Casing-Front - Parts For Series III Saloon | Jaguar Heritage Parts UK
