Draining/refilling coolant procedure?
Received 2,637 Likes
NBCat
There is no particular technique needed for re-filling the six cylinder XK engine, apart from making sure the heater valve is open when filling. When I did it, I used to fill to the top where the blanking cap fits, put it on, start the engine and rev up a few times, (engine only warm, never hot), then take cap off and top up. There needs to be a pint or two of coolant put into the expansion tank too.
Draining involves the drain plug at left rear of the block, down near to where the cylinder head oil feed pipe is located. Earlier cars had a little tap, but eventually this was dropped, because it blocked up. Even taking out the plug may still require poking around with a bit of wire to loosen up the crud. I don't think there is a separate drain on the radiator, you have to take off the bottom hose, but I may be wrong on this one.
The V12s have bleed valves in certain places to use while filling.
X308XJR
05-20-2019 06:50 PM
