Driver side windows and sunroof not working
Well my drivers front and rear window and also my sunroof has stopped working. I found a blowm fuse on the passage side under the glove box I believe it was 3A fuse. I replaced it and all the windows started to work again even the sunroof. Shut the car off and then a couple hours later had to go somewhere. I started the car and tried to put the windows down and the driver side windows and the sunroof will not work again. So I thought maybe it blew the fuse again so I check the fuse. Fuse is fine and every other fuse in the car is fine. Any ideas
Received 9,204 Likes
Received 10,871 Likes
Probably a blown circuit breaker.
This should help
Power Window Circuit Description and Diagnosis
This should help
Jag7651 (04-19-2016)
Received 2,399 Likes
Two added ideas:
1. Ditto on LnrB's idea. I call it the finger roll. Works!!!
2. By sheer coincidence, the driver window and sun roof
rocker switches have corroded to the point of non continuity.
Fiddly, but simple to remove them, open them up and clean
the teeny contacts.
The latter just a Jaguar thing...
A small Pozi drive, a blade drive and two pans are all the tools one
needs to do it... Been there, more than once!!!
Carl
the teeny contacts.
Carl
Johnken
04-14-2016 12:34 PM
wa3ra
04-12-2016 07:40 PM
