dry sump ajv8
That's quite ambitious. But why? Nothing special about an AJV8. Not particularly reliable or powerful and a mountain of serious technical problems await you. A better Jaguar choice is the AJ6 / AJ16 and their derivatives.
The only issues I was aware of with the AJV8 were:
Nikasil Cylinder liners caused by high sulphur fuels.
Water Pump impellers
Plastic timing gear failure
Throttle Body issues
I don't think the first is an issue any longer, at least in the US with lower sulfur fuels. The latter three are relatively easily dealt with. Perhaps I was just lucky, but the 99 XJ8 I had was one of the most trouble free cars I ever owned!
As for the ease of a swap or dry sump, I don't have a clue!!
Received 2,399 Likes
Sump issues have been dealt with in the past and recent time sans going to dry sump. Dry sump isn't really dry, merely a smaller sump.
What is the issue? Front deep part fails to clear the cross member?
Classic issue in other critters from way back. Dealt with then
and can still be done.
Move the pick up and adapt the sump, (pan) in USA speak. Easier in tin, but quite doable in alloy....
Carl
Carl
avos
380
12-14-2016 12:14 AM
avos
04-11-2011 02:07 AM
avos
09-12-2010 06:45 PM
