Engine compartment wiring covers
Received 10,944 Likes
Help!
I've always liked the engine bay wiring covers. After 1982 or so Jaguar stopped installing them but I always liked them so bought a set from David Boger for use on my '85.
There are three covers. The location of two is easy to determine...forward atop the inner fenders...but there's the third one has me stumped. I simply cannot figure out where it would fit.
The picture shows one the two forward covers in place. The mystery cover sits atop the fender.
Can anyone tell me where the mystery cover should be located? Or perhaps have a picture?
Or maybe David will see this post and remember the fitment
100 thanks,
100 thanks,
My thought as well but I've done everything except stand on my head trying to find how it might be positioned. It interferes with everything.
I'll try again in a few days....maybe a look with fresh eyes will yield an "Aha" moment !
Cheers and thanks
Doug (10-22-2016)
Doug: jaguar deleted these covers as a cost-saving measure (they must have saved about $0.75 per car) at the end of the 1981 model year (they also eliminated for a short time the map pockets at the rear of the front seats for the same reason - but that did not last long. The wiring covers were gone for good though...)
I retrofitted the covers to my 1982 car (the white one - do you remember it?) and I can tell you that there were only two, not three covers. The extra one you have is not from a Series III fuel injected car as far as I know.
Doug (10-22-2016)
No, it is not a cover for the spark plug wires - the Series III never had any such cover.
Doug - that white 82 xj6 was my first Jaguar and you might remember that I did a "rolling restoration" on it, replacing every worn/scratched/faded piece anywhere on the car - and ended by replacing the interior entirely, replacing every bit with new OEM leather and door panels, and raising it to the level of a Sovereign with reading lamps, console extension, rear headrests etc.
I loved that car and it is still going strong with a friend in Louisville, Kentucky. Sadly, I have only one photo of it...
Turns out it is the LH cover for a Series II.
The Series II cars has the headlight relay mounted near the radiator rather than the inner fender mounting found on the Series III cars...thus the longer length
