engine dies while running after some time
Hello,
I have a 85JagXJ6. The engine will start fine and idle for many hours. Now when I start driving after 45 mins to 60 mins it will stall then engine die. I will wait for 20 to 30 or so then it will start again and run.
Would anyone have this issue before? Could you please tell me how I can resolve the this issue, I really love my 85JagXJ6.
Thank you very much.
SanJ
SanJ
Doug (06-06-2017)
Welcome to the forum SanJ. please post an intro in the new member area for a warm welcome.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Hello,
SanJ
SanJ
Both the ignition module (AC Delco #D1906) and the ignition coil are known to give trouble when hot and then work OK again after cooling down.
Next time this happens check for spark at the plugs. No spark or a weak spark obviously suggests an ignition problem. If spark is strong then explore fuel system possibilities
Post back for more details, if needed
FS[Australia]: complete running 3.8 XK engine and Auto
Stoney85
10-11-2016 06:24 PM
