Engine identification - 7L49387
It will definitely fit the engine. It needs a thermostat housing, and one of the long studs is either broken or missing. They do frequently break and corrode, so check if there is a stub left at the bottom of the hole.
I'm not an expert of Strombergs, I believe they were 1.75" bores. There were 2 carb manifolds made for 1.75" carbs and 2" carbs, I'm not sure if the bolt pattern is identical or not. It is for SU carbs, I don't know for Stromberg. I generally prefer SU's, as they are much more adjustable.
You can use a modern aftermarket gear reduction starter, they are available from all the usual sources. There are two models, one fits 3.8 bellhousings with a 104 tooth flywheel and the other a 4.2 bellhousings with a 133 tooth flywheel. If you have a 4.2 flywheel, you can get a 104 ring gear for under $100 and have machine shop remove old ring gear (133) and install new one to match bellhousing and starter.
Bellhousing, flywheel and starter must all be from same series. They as a set, will bolt up to a 3.8 or a 4.2 engine.
If you have Auto Trans, you will have another two geared starter options, again Bellhousing, Flexplate and Starter must be from same series.
Rgds
David
Is there a basic 3-bolt thermostat housing, just a hose fitting, that would fit this manifold? Or is it a box shaped housing with a fill cap and hose fittings?
It's two seperate pieces. There is a spacer that contains the thermostat and bypass port; and then the hose outlet. There have been a variety over the years depending on the car. You might contact David Bodger at everydayxj.com, he's a great source for various parts like that.
I am assuming you have Manual Transmission ( some automatics have 132 tooth Flexplate ring gear)
Rgds
David
Rgds
David
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1200x1600/1952_starter_878e8b889b5582a51b1acca7ab6450a442ce0b78.jpg)
1952 Starter
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1200x1600/1959_starter_3d294dee245c0c3209f57af355ec724377612920.jpg)
1959 Starter
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x901/starter_19c4446bf65574b614d421ec806fb2f0574ab0cd.png)
Starter that came with 3.8
It looks like the 59 is what Moss is showing, N/A with them now, but $650 core charge for rebuilt ??
https://mossmotors.com/jaguar-early-...ition/starting
With respect to your project, which looks great, the rebuilding of a 4.2 engine for a one off classic, I would not use that manifold as a starting point. In my opinion that manifold is one of Jaguar's worst designs. You are giving up 20-25 HP to build engine around a "smog" manifold. The 420G or Mark 10 tri-carb manifold or XKE tri-carb manifold are immanently better as a starting point.https://mossmotors.com/jes-9249-cool...stem-mk-x-420g
Used 420G manifolds are half the price of E-type manifolds, both of which flow better and parts are still available.
See my XKE upgrade thread for back ground.
https://www.jaguarforums.com/forum/e...retion-214389/
PM me with any questions on modification.
Rgds
David
Rgds
David
jayd2
07-10-2024 09:50 PM
