Engine Number
in Left Hand Drive 6-cylinder cars it would be on the block's flange (where the oil sump meets with the block), at the rear of the block, sort of hidden behind the oil filter head assembly. A flashlight helps to see it, it's in raised numbers and letters.
Received 10,880 Likes
On the V12 engine you'll find the engine number at the rear of the "Vee", roughly in the area of the oil pressure switch. It's very hard to see with all the engine plumbing in place.
KarimPA
09-03-2015 07:32 PM
