engine oil dipstick tube seal
Old 10-01-2020 | 07:15 AM
Jose's Avatar
Default engine oil dipstick tube seal
the cone-shaped seal located at the dipstick is shaped like a "cone", i.e., one end is wider than the other. I have three dipsticks, two with the same cone-shaped seals.
I started to look for new replacements and find the design has been changed to a "cylinder-shaped" seal which doesn't work in the dipstick tube, it simply does not stay in place and in fact, the dipstick is pushed out of the tube by itself in a matter of hours.
I checked with David at everyday XJ and he has the "new design" seals. Same with SNG Barrat and everybody else. I have the "new" seal too.
but it doesn't work. This must be a mistake in the Parts manual.
the original seal is a solid, cone-shaped rubber piece. The new seal is a hollow cylinder. ???
Anybody else came across this ?
Old 10-01-2020 | 08:12 AM
worzella's Avatar
Originally Posted by Jose
the cone-shaped seal located at the dipstick is shaped like a "cone", i.e., one end is wider than the other. I have two dipsticks with the same cone-shaped seals.
Jose -
I just replaced mine and had the same thoughts. But mine seems to work fine. But I will walk out later and double check how firm it has stayed in the tube
You know after thinking about it I concluded ( probably incorrectly) that the original was cylindrical but that after years and years of heat on the bottom side that is in the tube and exposed... that it shrunk up and therefore appears to be tapered????
Will report back shortly
Randy
Old 10-01-2020 | 08:38 AM
Jose's Avatar
Randy thanks.
I thought the same thing but the new seal is hollow and the old tapered seal is solid.
to me the old one looks like one of those plugs used in plumbing to seal the sink's drain when filling the sink with water.
Old 10-01-2020 | 11:24 AM
Jose's Avatar
a rubber stopper, that's what the original dipstick seal is. They are available from many suppliers.
Jag7651 (10-01-2020)
Old 10-01-2020 | 05:08 PM
yachtmanbuttson's Avatar
This is from my 1975 Series II 4.2L engine.
Old 10-01-2020 | 05:22 PM
Jose's Avatar
exactly, the tapered plug / seal. Just like in my dipsticks.
David told me he found two dipsticks also with the tapered seals, so it is obviously how they came from the factory.
that new seal design is terrible, I will not use it, I don't trust it.
Today I wrote to several tapered plug businesses with the measurements to see if they have High Heat Resistant plugs. One company offers them for 600 degrees F temps.
I will find them.
Scout66 (10-29-2020)
Old 10-01-2020 | 09:35 PM
Yellow series3's Avatar
When I took chemistry in college they had similar plugs that fit in test tubes. My restored 87 has the tapered type and was replaced by the previous owner.
Jeff
Jose (10-02-2020)
Old 10-02-2020 | 07:34 AM
Jose's Avatar
ACE hardware has an aisle of specialty hardware and they have a box of tapered plugs, but they are not heat or oil resistant and I would be afraid of one getting melted in the dipstick tube. Silicone would be nice.
Old 10-02-2020 | 05:27 PM
worzella's Avatar
Odd. Mine is the non tapered new style and when I went to check it, it was stuck in the tube. Ha ha... so anything can happen I guess!
Jose (10-02-2020)
Old 10-02-2020 | 05:49 PM
Jose's Avatar
I wonder how many owners are having this problem with the hollow seal.
I found a solid tapered silicone stopper that might work. Waiting for a sample, good for 600 degrees Farenheit.
Old 10-29-2020 | 06:11 PM
Scout66's Avatar
Default Oil Dip Stick Seal/Stopper
I also have the tapered cone shape seal. I think it’s no longer sealing well, and a small amount of oil is leaking out past it. So, I’m searching for a new one.
Old 10-29-2020 | 06:19 PM
Jose's Avatar
same with mine, it has become brittle and also has shrunk. I am still looking for them but they have to be heat and oil resistant, they must be made of Neoprene at the very least. Silicone does not work, already tried it, it turned into chewing gum.
The substitute hollow seal sold by everyone does not work either.
roger.neill
07-30-2021 03:57 PM
John Baker
06-03-2020 06:00 PM
JensenHealey
XJ40 ( XJ81 )
02-08-2020 02:00 PM
osyris
11-26-2013 08:07 AM
Quick Reply: engine oil dipstick tube seal
