engine & suspension swap
Regards,
Andrew.
If you can find an XJS it's a much easier swap. Motor and trams will almost bolt-in. Other smaller parts like the radiator and A/C lines will also "fit" with modifications. The complete XJS upgraded front and rear suspension will also bolt in with minor brake plumbing mods. XJS are cheap around here you can sometime but one for a very low cost. I'm not sure of the market in your area but I suspect it's similar.
juha_teuvonnen
12-26-2016 07:30 AM
SebastianSE
11-12-2016 02:47 AM
texmanmoore
08-16-2011 10:09 AM
johnfrye
06-10-2008 09:50 PM
