Engine swap
Not AFAIK or hope. The issues are more with getting the correct matching drive-train for the manual setup, but you have those already. Maybe a few hose differences but again you have those on your car. I think the auto had an oil cooler for the transmission.
If you can hear the engine running and maybe perform a compression test on before buying it.
Accidentaljag (02-22-2016)
I'm pretty sure you'll have to use the autobox and send all the manual bits to me. Pm me for the correct address!
Staying with the manual, definitely. The current engine has no compression in 2 cylinders, with a third dodgy. So rather than getting the engine rebuilt (which I can't really afford), and assuming I'll end up with parts left over if I strip and rebuild it, I thought an option would be to get a donor engine.
Thanks for the offer Slofut, if only I'd known earlier haha
