engine will start will not run
Hi I've moved your post to the XJ6 technical section where you'll get more help.
Please take time to visit
https://www.jaguarforums.com/forum/n...-intro-must-5/
and introduce yourself so we can say 'Hello'
Received 10,880 Likes
Here's an easy place to start: carefully examine the ducting between the air flow meter and the throttle body. Any holes? Is is properly seated and secured?
If that doesn't pan out post back with more details about the problem. Does this happen only with a cold engine? Any black smoke from the exhaust? Is the throttle blade set to the proper .002" gap? Does it restart easily?
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
