Exhaust Tone
Is this the sound you're searching for? Raspy Idle
I hope this link works, first time linking to my G-Drive.
Very cold start. Had to feather the pedal to keep it running. Probably was the first or second time starting it after winter hibernation.
Exhaust was stock, but had numerous leaks in the pipe between the cat & the first set of mufflers. Recording it in the garage exaggerated the sound on the recording.
Not going to be a sound you can replicate, but I really like the way that video made it sound!
#28
Btw... My daughter drove it to high school like this, she got the same comments.
yachtmanbuttson (08-11-2018)
I'm supposed to get back today the Y pipe with the CAT gutted and I'll put that back on. But I don't expect to hear what I want to hear as the four rear silencers are still in place. Next step will be to eliminate the forward two silencers with straight pipes (actually slight S shaped pipes), then see what that sounds like. Final step would be to eliminate the two rears. But with the CAT gutted I don't expect that I need to eliminate the two rears.
#30
Well, I've installed the new exhaust system and don't notice much of a difference - disappointing. The single pipe comes from the exhaust manifolds, then to the gutted CAT, dual pipes out of it and straight back, up and over the rear diff carrier and then to the two stock rear mufflers, out the S pipes. So, I've eliminated the two forward mufflers. My last resort will be to remove the two rear mufflers (I expect it to be too loud) when I bring the car to be painted as the two pipes stick out through the rear valance. Maybe something like "cherry bombs" in their place?
#32
One never knows???
My car came to us with the DOHC running nicely. To my "challenged" ears, quiet.
One cat, two OEM mufflers and "cherry bombs" as the resonators at the end.
Out with the failed, DOHC. In with a nice LT1. Local muffler shop and I designed the exhaust. Two cats to please the SMOG gods. An H pipe to smoothen the rasp. All else JAG, "cherry bombs" kept. Very pleasing V8 burble. More thn one in the kinow recognized it as V8 noise. Not a racket, just right....
Carl
Carl
#33
#34
Yes, will definetly run straight before investing any more for sure. Except... I have a new vibration when I rev the engine that I didn't have prior to gutting the CAT and removing the two forward most mufflers, and replacing with just pipe. I have diagnosed it to weak OEM muffler hangers. So I ordered new rubber from SNG Barrett this morning and now I have to take the entire muffler system back off again, remove the hangers and rebuild them. They do look pretty poor. Should have done them when I was doing the exhaust work, but that's not how I do things. It seems like I have to do things four times before I get it right! Please tell me I'm not alone in that.
#38
#39
Well, after taking the entire exhaust system down from exhaust manifold junction to the S pipes, I found ALL of the muffler hangers in need of replacement. I ordered them from SNG Barratt. It's a wonder it didn't vibrate and shake before. Maybe it did and I didn't notice. I'm glad I'm finally doing the job correct now. I'll try the no rear mufflers part before I put it back together to see how it sounds. I'll keep you posted.
