Extra wires after the engine conversion
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1600x1200/p1030958_531a2ee491aa93bc66baebcf3eaa1539aa5d278d.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1600x1200/p1030954_227c941dea0b465d74fd2f85b70580c099614ff9.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1600x1200/p1030955_571aed69e14ae0c87b4d8ee325d5fd0bb1ae4f62.jpg)
I'm coming back to the well to ask for a little more help. Can anyone tell me what the heavy blue wire with the single male bayonet terminal goes to? There was nothing in the engine bay when I got the car and I don't believe I've ever seen one like this. It looks like it is part of a weather resistant connection that carries a good amount of current. It's in a special fiber sheath for most of its length. The other pic's show what the wad of wires that were in the engine compartment look like now that they are inside the passenger compartment. The wire in question was in the engine compartment. Thanks for any opinions.
Dave
Received 2,399 Likes
Opinion is all I have to offer:
1. the "bus" bar on the wing wall by the battery is foreign to SIII cars !
2. Same for the one in the first picture. Not a jaguar thing??
3. Odd wires always suggest added items.
Security system.
Remote FOB.
Car phone.
Sound system.
4. check the S57 Jaguar schematic. Very good on wire colocations of electric device .locations .
Giordan knot???
Carl
Security system.
Remote FOB.
Car phone.
Sound system.
Giordan knot???
Carl
The bus bar is one that he added to clean up ground connections i believe. The style he used, i think, is more for a general purpose electrical wiring, im guessing house electrical. They are available at home depot. I had grabbed a couple originally for the same purpose before I had decided to just completely redo my entire wiring harness.
That wire does look really odd. It is a spade connector with a huge weather proofing sheathe. Never seen anything like it before. Maybe you can continuity check it and try to figure out where it comes from deeper in the car.
Thanks Ys-3, that's the exact wire I was asking about. The shielding around the inside is what makes it look so big.
Yes Carl, I added those (3) ground busses to simplify and consolidate all those little black wires that were laying around the engine compartment. I have made smoked plexiglass covers for them and I'm happy, function over form has always been my preference. I did a little looking around, but I knew I would find the ones I wanted a the local West Marine store. They are rated for 150amps and are nickel plated copper, pretty beefy. The wad of wire you see in pic #3, Carl, is what came out of the engine compartment. There is another one on the drivers side that was a horrible installation of a car alarm. Its day is coming.
Thanks again to all, I appreciate the help.
Dave
Dave
ating OK !! I did something like that. I bought a terminal at a hardware store. not ganged, though. I made it that way by adding a brass strip to connect the several contact points. I mounted mine to the right of the rack for the Jaguar relays . That little rack was removed and a larger one installed there for most of my relays for the LT1. Obscures the VIN?? So, what. Neater. A row of relays with markings and a ground bus to the right. That bus grounded by a black wire attached to the battery ground and terminating at the same wing wall bolt.. Except the ground leg for the starter relay.. It goes in to the cabin to the micro switch on the shift tower. MY shift tower is from an XJS and as such is more compliant of the GM positions.
But, ugh, my Jaguar is having a hissy. Cranks healthily, but no fire... could it be that I need to switch feed tanks??? We will see, or will we???
Carl.
Carl.
SilverStreak
08-19-2018 01:57 PM
Roger Mabry
03-23-2015 04:50 PM
Blaze Falconburger
09-19-2013 04:01 AM
