Failing Head Gasket ?
Old 02-27-2016 | 09:32 PM
Lagonia's Avatar
You guys are machines!! Awesome job!!
o1xjr (02-27-2016)
  #102
Old 02-27-2016 | 10:19 PM
Daf11e's Avatar
Great opportunity to clean up the engine bay.
o1xjr (02-27-2016)
  #103
Old 02-27-2016 | 10:22 PM
Gracious, you guys don't waste time!!
  #104
Old 02-28-2016 | 12:00 AM
o1xjr's Avatar
Originally Posted by o1xjr
We will move mountains to have "Miss Fireball" on the road for O'Rielly's Sunday week.
We are still optomistic, picking up the short motor Thursday. Hope to have it running by the afternoon and a shake down run Friday, ready for the forum meet Sunday.
The following 2 users liked this post by o1xjr:
LnrB (02-28-2016), paulyling (02-28-2016)
  #105
Old 02-28-2016 | 12:10 AM
yarpos's Avatar
I never quite believed the stories I heard about Aussies being alcohol fueled until I started hanging out here!
I had not been told the half of it!
Dont forget , nor down play the NZ connection. The Kiwis rightly say they punch above their weight, alcohol consumption is in there somewhere also just quietly.
LnrB (02-28-2016)
  #106
Old 02-28-2016 | 12:36 AM
o1xjr's Avatar
We both grew up in NZ. (but Australian now)
The head will be sent to a very reputable shop for them to weave their magic.
If the block needs any attention we will probably engage the services of Murray Scoble
Home - Peninsula Jag We are planning a forum visit to his workshop, hopefully as our next outing
Pretty much keeping everything stock though.
As I said early on in the thread, We would use Peninsula Jag if we had to go deeper.
I have paid the asking price so the engine is mine!
Internet is a wonderful thing, contacting the engine builder via Facebook at 10 am Sunday and owning the engine a few hours later.
  #107
Old 02-28-2016 | 03:06 AM
Richard_gib's Avatar
Yes, well, ummm...... Over here in New Zealand, it is legal to distill your own spirits and brew your own beer. Makes for some fun weekends. The aussies are fueled by alcohol due to the heat and the lack of water :-) Nothing cools ya down after (or before) some hard work like a cold one :-)
Grant Francis (02-28-2016)
  #108
Old 02-28-2016 | 04:01 PM
Stoney85's Avatar
As mentioned, now is a great time to get that engine bay sparkling while the great lump of iron is out of the way.
A very unfortunate circumstance to have happened, and not a cheap venture either, but a completely new motor will now reside in that bay.
Is the rebuilt bottom end just done to factory specs, or was it blue printed? raised compression? lightweight pistons etc?
  #109
Old 02-28-2016 | 06:19 PM
paulyling's Avatar
Hope it all goes well for the new install on Thursday mate. Here's to Fireballs speedy recovery!
o1xjr (02-29-2016)
  #110
Old 02-29-2016 | 02:55 AM
o1xjr's Avatar
I'm not certain of the specs, which is fine with me. He gave the complete run down of what was done to my mechanic friend. As soon as the builder started running through the specs I put him on to Phill.
Since he thought it was a good option, I went with it.
paulyling (02-29-2016)
  #111
Old 02-29-2016 | 07:03 PM
Stoney85's Avatar
Was the previous motor the original one untouched?
If the new motor has been built with some care and attention to detail, you will love it, a properly modern balanced motor is such a nice thing to have.
All the motors I have built, I usually aim for matched rods and pistons to within 0.5grams, and grub screwed and balanced cranks etc, so much smoother especially when working with an older mass produced motor. I find some peace within, when I blueprint a motor, rewarding experience only other true petrolheads would understand.
o1xjr (03-01-2016)
  #112
Old 03-01-2016 | 06:22 AM
Woznaldo's Avatar
Amen to that!
  #113
Old 03-02-2016 | 03:17 AM
o1xjr's Avatar
Default Big Day Ahead
  #114
Old 03-02-2016 | 03:30 AM
andrew lowe's Avatar
It turned up early then?
Thought you said it was due Thursday!
Gives you a bit more time to get it installed and dialled in.
  #115
Old 03-02-2016 | 03:35 AM
o1xjr's Avatar
Phill and I took a few of hours off today to save 4 hours driving time tomorrow picking it up. 4 valuable hours we can use tomorrow.
paulyling (03-02-2016)
  #116
Old 03-02-2016 | 03:49 AM
paulyling's Avatar
Best of luck mate.
Hope it all goes well and will be eagerly awaiting the outcome on the forum
o1xjr (03-02-2016)
  #117
Old 03-02-2016 | 08:36 AM
JagCad's Avatar
Nice clean machinery. Definitely to be admired. It deserves a nice clean engine bay.
Great work.
When my engine bay was empty after the DOHC expired, I
cleaned it a lot. Not concours, but decent. The front cross member was the grimiest. Oven cleaner did the grime in, paint and all!!!
No matter, sprayed it black along with other tin. In went the
power washed LT1. Looked great. Connections began, but in a clean environment, so much better.
It continues to purr....
Rain incoming tonite. We need it badly. It will impact my spring clean up!!!
Carl
o1xjr (03-08-2016)
  #118
Old 03-02-2016 | 09:39 AM
Wouldja just Look at that!
Plastic wrapped short block, such a beautiful thing!
o1xjr (03-08-2016)
  #119
Old 03-02-2016 | 08:31 PM
o1xjr's Avatar
paulyling (03-03-2016)
  #120
Old 03-02-2016 | 10:03 PM
Clarke, I'm not sure you fully appreciate the value of your willing, knowledgeable, dedicated and talented assistant.
Whatever you're "paying" him isn't Nearly commensurate with his true worth!!
o1xjr (03-03-2016)
Quick Reply: Failing Head Gasket ?
