Fix to my non-responsive climate control
It's been a journey almost a year in the making when you factor in 6 months worth of frustration breaks. First it was swapping out the compressor, driver and expansion valve (that was fun). Then the ac charging tech informed me I had no lower compressor mounting bracket. Go find one of those and install it. Sounds simple but stupid me did not think to check with Dave at everydayxj. Then I discover I have no power to the entire climate control system. Now it's winter in Michigan so there goes 4 months. I get into it again in May and I find a video on YouTube from Allen Bradley showing his amplifier which is what the photo is. Before he sold me one he painstakingly walked me through what seemed like 25-30 tests before he helped me discover that I also had a bad master switch. The switch was not fun to replace at all. You have to remove the console, radio faceplate and radio and the assembly with the trip computer just to remove the bracket that held the switch. Pre-assembled everything and the jag gods must have felt sorry for me but cold air came out the vents when I fired it up yesterday. So far so good. With Allen's amp, you set the climate switch to auto and use the temperature selector to not only adjust the air temperature bit it also drives the fan speed and vent selection. Pretty cool (pun intended) . Now I can go back to the fun stuff like going from 5.25" to 7" outer headlights.
The following 5 users liked this post by retroren:
Coventrywood (07-09-2022),
Doug (07-09-2022),
Greg in France (07-09-2022),
LnrB (07-08-2022),
yachtmanbuttson (07-09-2022)
Received 9,470 Likes
Lnrb, don't you know it. To think I got it working the day before I was to take it to a very busy and expensive repair shop specializing in older European cars. I had made that appointment 2 months prior. I figure I kept at least a grand in my pocket so I can go shopping for a trinket or two. Maybe a new set of chrome wheels and tires????
LnrB (07-09-2022)
Greg in France (07-11-2022)
(humor follows)
GASP!!!!
But if you do that, it will no longer be (here comes the sacred word) ORIGINAL!!
And you will have made (here comes one of their favorites) DOG WASTE of it!
And you will have (here comes another of their favorites) DESTROYED its "value!"
(/humor)
Mind you, those who will say that don't OWN your car, nor do they have to live with it, nor are they likely in the market for one.
I'm a firm believer that It's YOUR car, and whatever you need to do to make it better for YOU, Go for it!
GASP!!!!
(/humor)
The following 4 users liked this post by LnrB:
The following 3 users liked this post by LS3COUPE:
Over in the Xjs section, Thomas Thorsen did that with his car last winter and documented it in great detail.
You might find some useful hints there.
retroren
08-05-2021 07:36 AM
Skidz
11-03-2010 03:17 PM
