Flasher Relay
If the car is a Series 3 XJ6/12, I think it's still that car in '89 rather than the next platform, it's on the panel next to the under dash fuses, driver side.
I think you can get to it thru the fuse access opening and can avoid the bother of pulling the under dash panel. Does that help?
I attached a picture from the S57 manual in the next that shows where.
Last edited by nileseh; 06-11-2022 at 08:40 PM. Reason: mistake, tried to past a picture.
If your car is a 1989 model XJ6, it is NOT a Series III car, and no reference to the Series III car will be of any help to you. Your question should go to the next generation XJ40 list (yes, the badging on your car may say “XJ6” but your car is known by the factory code: XJ40.
motorcarman (06-14-2022)
Sorry for the confusion. I think at one time I saw a timeline for manufacturing date ranges for these cars, perhaps with VIN reference as well. There must be a character in the VIN that designates the series type. I recall that the Series 3 XJ6 was sold parallel with the XJ40 as late as 1992, but I may be wrong. The XJ40 was first manufactured in 1987 as I recall. I've been told that some regard the XJ40 series was the last and best all-Jaguar sedan insofar as the succeeding X300 series (I have a X305, XJ12, a great car) was under Ford ownership.
Sorry for the confusion. I think at one time I saw a timeline for manufacturing date ranges for these cars, perhaps with VIN reference as well. There must be a character in the VIN that designates the series type. I recall that the Series 3 XJ6 was sold parallel with the XJ40 as late as 1992.
but note that these were all V12 cars, not XJ6 models.
Received 10,916 Likes
A Series III XJ6 will have a VIN ranging from 300001 to 477823. (The Series III V12 cars went to VIN 486xxx)
The 'XJ40' models had a VIN sequence starting with 500515
The 'X300' models had a VIN sequence starting with 720001
