free car?
Guest
Posts: n/a
I was given a 1985 vanden plas. With no title and no record at the DMV. It has been sitting in a garage for a long time. There is slightly over 10,000 miles. Almost 100% original. It even has the original tires. My mechanic said the break calipers are frozen, possible head gasket is leaking, and he suspects that the rings are rusted because it takes a lot of effort to turn over. His advice is that it will cost as much to get it running as it is worth ($8,000-$10,000). He has offered $1,000 cash. Should I take it?
It is hard to answer because the question has two components to it - Logical and emotional. I couldn't begin to gauge your passion for the car. Strictly on the logical side, the answer would be yes, take the $1,000.
If all of the tech's diagnosis is correct, there are going to be other mechanical issues once the car is running. Could be a transmission, differential, electrical gremlins, or numerous other engine issues etc, etc. The head gasket alone is a nightmare on an SIII that has been sitting for years. You could probably do better than $1,000 parting it out, which is probably what the tech is thinking, but then you have to have the room to do that.
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
