Free Series 1 XJ6 parts,Brisbane.AU
Old 11-04-2015, 06:49 PM
Roger Mabry's Avatar
Default That heater part can be fixed easily
I use small brass OD tubing from a model shop... shove it in and use epoxy to seal all around the new tube. Then you have to use a smaller
piece of hose adapted to the original larger size...
DO NOT THROW THE PART AWAY. New ones are not available and most used ones are broken like yours...
Old 11-05-2015, 12:20 PM
Japawels's Avatar
That is exactly what I've done after unsuccessful search for a new one Works just fine.
Old 11-06-2015, 02:16 PM
o1xjr's Avatar
Received 6,327 Likes on 4,370 Posts
daf11e
Left interior pillar light lens
Boot carpet
smith356
Quarter window knobs
Sun visors
7" headlight buckets and hardware (with the chrome trims too)
Circulate/fresh air badge from centre console above radio
Wasnaldo
Both wing mirrors and remote adjusters
Chrome adjuster surrounds
Radiator support panel
Heater controls and brackets
Japawels
Right tail light lens
Both front indicator/park light lenses
Rear vision mirror
glass bowl type fuel filter
fresh air vacuum actuator
left quarter window with hinge
heater control badges, demist/facia
jag emblem where air con switch goes
Chapman
Steering wheel
Front seat pads, (seats,if they have height adjustment).
Old 11-07-2015, 04:35 AM
o1xjr's Avatar
Originally Posted by Woznaldo
Clarke, thanks for offering the heater controls in my stereo removal thread. I've pulled the stereo out and the centre slider control has a snapped hose attachment port, so I'll definitely need them!
Here's a pic of my broken one still attached to the support bracket:
Can you also grab the whole metal support bracket that houses the centre heater control and the stereo?
Woz, I found one in my stash tonight but broken in the same place. With luck the one tomorrow will be ok. As for brackets, if it is no good you can have this one I have spare.
I will send you the least molested one.
Originally Posted by ChampInSD
If someone wanted to hack up the left front fender, I could use the section cropped in the photo below. Mine has some damage and this would be very useful!
Sorry ChampInSD, will not be cutting panels.
Japawels
Pawel, I found this one in the parts I have stockpiled over the last 2 years. Yours if you want it, my car has air con(won't be needing it)
Old 11-07-2015, 04:58 AM
Japawels's Avatar
Originally Posted by o1xjr
Japawels
Attachment 121203
Oh yes, definitely
o1xjr (11-07-2015)
Old 11-08-2015, 05:45 AM
o1xjr's Avatar
Default Me and DR Phill
Well, after a 6am start we had a successful road trip to collect parts. 8 hours later we were back at Chateau Fireball having a coldie.
We left Rathdowney (after a quick scooner at the pub) to return home amid storms coming in two directions and made it about 1/3 way home before the trusty Jeep got hammered by small hail and big rain/flash flooding before we got to Beaudesert.
Sorry not much more to add tonight as a carton & 1/2 of 4X was enjoyed with the good DR before his wife drove him home.(Not happy ).The wife,that is!
Will get to sort stuff later in the week.
(Dr Phill has been my spanner man(advisor/mentor in all things mechanical) since 1983 when he was a first year apperntice mechanic)
Free Series 1 XJ6 parts,Brisbane.AU-dsc_4541.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4542.jpg
Daf11e (11-08-2015)
Old 11-09-2015, 05:54 AM
o1xjr's Avatar
Default daf11e
Pair of pillar light lenses, right one NFG but maybe repairable somehow.
Daf11e (11-09-2015)
  #28
Old 11-09-2015, 06:03 AM
o1xjr's Avatar
Default Woznaldo
Radiator support panel is welded in structure, not bolt off and was cancerous anyway like the rest of the body.
Both mirrors with controls but one mounting bezel missing. I think from memory I saw a pair online at Jag prestige, give Phill a call.
https://www.google.com.au/?gfe_rd=ct...62208138426129
Heater control/ radio bracket was worse(more butchered) than my spare and same vacuum outlet broken on both, looks like you will be heading to a model shop for propeller tube.
Old 11-09-2015, 06:12 AM
o1xjr's Avatar
Default Smith356
Sun visors
7" headlight buckets with trim
Circulate/fresh air badge (Leaving attached to panel to avoid me damaging it)
  #30
Old 11-09-2015, 06:18 AM
o1xjr's Avatar
Default Japawels
Right tail light lense
Both front indicator/part light lenses
Rear view mirror
Left front quarter window with hinge and gearbox
Demist/facia/car badge
Jag shield for air con switch hole
  #31
Old 11-09-2015, 06:22 AM
o1xjr's Avatar
Default Chapman
Steering wheel
Hot control badge
  #32
Old 11-09-2015, 02:17 PM
Received 3,963 Likes on 2,864 Posts
Thanks mate, my right one is good, left broken......FAB!
  #33
Old 11-10-2015, 03:17 AM
o1xjr's Avatar
I think I have two bases in better condition from my deceased ones, not sure if they can be changed. Will dig them out when sorting on Thursday.
Daf11e (11-10-2015)
  #34
Old 11-10-2015, 03:23 AM
Woznaldo's Avatar
Default Muchos Gracias.
As suspected on the Radiator Support Cross Member, happy with the mirrors. I'll get the prop tube from the model shop and get busy.
Thanks again for your efforts, very much appreciated and what this club is all about.
  #35
Old 11-10-2015, 05:57 AM
o1xjr's Avatar
Agreed ! We have just got to help each other keep these fine steeds on the road or we will all be paying Holden/Ford prices for parts too soon.
smith356
circulate/fresh badge
  #36
Old 11-11-2015, 02:46 AM
o1xjr's Avatar
Default Japawels
I have this one, the other is still on the car and has been drilled and and rivited.
Japawels (11-11-2015)
  #37
Old 11-11-2015, 06:34 AM
o1xjr's Avatar
Huge thanks to Jim for the generosity of his offer.
Many parts have or will be put to good use from Brisbane to as far away as Poland. I will post pics of the remaining parts I have available after I finish sorting and cleaning.
Daf11e (11-11-2015)
  #38
Old 11-11-2015, 09:38 AM
Received 9,300 Likes on 5,423 Posts
What a generous thing you've done, Clarke, you and your friend, Jim!
It had to cost you something, fuel at least, to strip and ship all these parts.
Even though I don't need any, nor would it be feasible to ship them from you to me, I've stripped a few parts off a couple junkers, and I appreciate the time and effort you've expended to spread One Old Jaguar all over the world!
Good Onya!
The following 2 users liked this post by LnrB:
Daf11e (11-11-2015), o1xjr (11-11-2015)
  #39
Old 11-11-2015, 03:17 PM
o1xjr's Avatar
Elinor, just a bit of time and fuel. Not much compared to the massive amount of help I have received from the members here to get my car sorted over the last 2 years.
The following 2 users liked this post by o1xjr:
Daf11e (11-12-2015), LnrB (11-11-2015)
  #40
Old 11-12-2015, 02:21 AM
o1xjr's Avatar
Default More parts
This is what is left over if anybody needs something.
Free Series 1 XJ6 parts,Brisbane.AU-dsc_4567.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4568.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4569.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4570.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4571.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4572.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4573.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4574.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4575.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4576.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4577.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4578.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4579.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4580.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4581.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4582.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4583.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4584.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4586.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4587.jpgFree Series 1 XJ6 parts,Brisbane.AU-dsc_4588.jpg
Quick Reply: Free Series 1 XJ6 parts,Brisbane.AU
