Front and Rear Windscreen
Hi All,
Please tell me if this sounds right. My 83 XJ6 is currently at the body shop getting rust around the rear windscreen fixed and then a repaint of the entire car. The body shop called to say that the glass guy they use says he will most likely destroy the rubber seals and chrome trim around the front and rear windscreen to be able to pull out the glass. He says the job will take 5 hours and he wants a fee of $1,000 to pull the glass. I am, of course, having trouble finding the replacement chrome pieces for the rear windscreen. Does anyone else find this odd that these pieces would be destroyed and that it would be a 5 hour job? Thanks!!
Received 10,920 Likes
The stainless steel trim pieces can be cut out of the rubber and saved…… but it takes lots time and patience. They are delicate. If, by chance, a previous installer glopped a bunch of urethane on them then that adds to the time as it all has to be cleaned off.
I myself have spent several hours removing the glass.
The following 2 users liked this post by Doug:
Childeric12 (07-30-2023),
Greg in France (07-27-2023)
The following 7 users liked this post by davidboger:
Doug (07-27-2023),
Greg in France (07-27-2023),
Jag7651 (07-27-2023),
Jose (07-27-2023),
Mkii250 (07-28-2023),
and 2 others liked this post.
Here in the UK I had both my screens taken out for re-sealing by a nationally known windscreen replacement company. One of their older fitters had done them before and managed to remove and refit both screens without causing damage. He used new rubber seals but did no damage to the stainless-steel trim and didn’t suggest that it was a possibility. They did them for their standard charge of Ł204 GBP (approximately $260 USD) each which seemed reasonable.
Perhaps try finding an ‘old school’ windscreen company to do the job.
The following 5 users liked this post by XJRAYUK:
Bill Mac (07-28-2023),
Peter3442 (07-28-2023),
XJJK (08-01-2023)
davidboger (07-29-2023)
Received 1,067 Likes
I cut the front windscreen seal out of my S3 XJ6 with a piano wire. My son inside the car and myself outside.
That did not damage the ss surround.
I did use a professional to put in the new windscreen as it is glued in place and is part of the overall structure of the car.
But I did the preparation of cleaning up the body work and surround so the pro. only had to do the fitting.
Mkii250 (08-01-2023)
I don't list a lot of larger parts on my site due to shipping costs varying so much depending on where the parcel goes.
If you want to send me an email (david@everydayxj.com) I'll be glad to help with those...
David
shop.EverydayXJ.com
Darrenmb
10-31-2010 05:21 PM
