Front Suspension Arms
Cool idea...I believe the control arms are cast steel. The upper could be easily fab'd up using a jig.... The Lowers are a bit more complex and would require a knowledgeable fabricator. Really not necessary though since you can just run spring seat spacers. I did that and used a larger tires to fill the wheel well for a lowered look.
I plan on doing it for the weight savings alone...I've already got alu calipers and alu hat rotors and the improvement in wheel dynamics was noticeable with 15 lbs of less unsprung weight per wheel.
Cast steel was my worry as this would limit trying to fabricate something.
Hadn't thought about reducing unsprung weight to be honest but it'll certainly not do any harm if I get some arms fab'd up
Altering spacers wont really be enough for the amount I want to lower it by. I want to fit air bags on the front so that I can run the car much lower than standard but then raise it up so that I get over speed bumps etc.
On the rear I'm going to use adjustable coilovers.
