Front suspension clanking
I'm just trying to plan ahead, but my '83 XJ6 has this clunking sound when going over bumps and it sounds exactly like the noises coming from this video:
1988 Jaguar XJ6 - YouTube
This guy says it is his driver shock tower mount.
I was looking through the factory service manual procedure, and I don't see where this shock tower mount is. Is it part of the actual shock/damper?
By the way, these are the easiest to change shocks I've ever seen in a car!!!
There is another source of noise, the anti-roll bar bushes, which wear out, so check these out, plus the bushes on the links.
At the top of the shock there are two rubbery/plastic bushes to insulate the shock from the car body, about 1.5" iin diameter, and about 1" thick, with large washers on one side. Eventually the one on the inner wing side gets worn out and squashed up so the shock, now being a bit loose at the top, can now bang against the car body as the suspension works. I believe you can get these bushes separately. At the same time, the bottom bushes should be replaced as these will likely be worn out. Before you do all this though, make sure the shocks themselves are not shot.
Thanks. How do I make sure the shocks are not shot? I have tried pushing down on the corners and the car does not bounce repeatedly or make noise. I guess I will check them for leaks. I think I found these cushions separate but they are almost as expensive as a shock!
I'll probably replace the anti roll bar bushings as well just because they are easy to get to.
amcdonal86 (01-16-2012)
Mugatu
22
06-23-2020 01:50 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
