Front Suspension Rebuild Manual
Received 10,876 Likes
The front suspension on the XJ6 Series 1, 2 and 3 was the same throughout its life, but the dampers and springs varied. The springs are very powerful, and you really need to use the factory-type compressor up through the middle of the spring. These springs can kill if released suddenly.
You may not know, but the top and bottom balljoints for the later XJ40 are a retrofit and last forever, unlike the old ones, especially the lower ball joint with its adjuster shims etc, which dates from the Mark 1 saloon of 1955 !! It is totally inadequate for modern cars and tyres with the cornering forces that can be generated with wide radial tyres. Lemforder make the ball joints and they are not expensive.
Do not forget to note the position of the shims by the top ball joint; these must go back as found. Note also there is normally a shim (fairly thick) between the steering arm and the caliper (common fixing bolt). This MUST GO BACK AS FOUND. People that have left it out and just screwed down this bolt have distorted the arm and some have broken leaving no steering.
02jagstype
09-04-2015 08:20 PM
