fuel cap question
I was pulling last of chrome off before car goes to paint, and when i pulled gas caps there is a rubber line on the front that got broken on one side, Does anyone know where the other end of that line is? do i need to replace that line before it goes to paint or is it simple and can wait? i looked in my haynes (manual, not underpants) and found nothing about it.
im sure i can figure it out, but sometimes its easier to ask than dig for an hour or two to find out i coulda just undone a screw somewhere and it popped off. any help greatly appreciated!
Received 6,327 Likes
Just removed my filler cap, can't really see what you mean. Bought it upstairs and took some shots on the kitchen bench (44c in the garage today). Maybe you could point out what I am missing. Someone will have an answer.
Got to put it back on now because my daughter and her boyfriend are taking it out tonight.
You probably guessed by now mine is the forum pull a part photo car for series 1 junkies.
![fuel cap question-dsc_1000.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/100675d1480974325t-fuel-cap-question-dsc_1000.jpg)
![fuel cap question-dsc_1001.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/100676d1480974325t-fuel-cap-question-dsc_1001.jpg)
![fuel cap question-dsc_1002.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/100677d1480974325t-fuel-cap-question-dsc_1002.jpg)
![fuel cap question-dsc_1003.jpg](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/100678d1480974325t-fuel-cap-question-dsc_1003.jpg)
Darrenmb (11-15-2014)
10.40 pm, just cracked a cab/sav and going to settle in to some forum reading.![Icon Slap](https://www.jaguarforums.com/forum/images/smilies/icon_slap.gif)
Nothing like that on mine, but looks like some type of breather or overflow. Either way not a biggie.
Fireball is entrusted to the daughters boyfriend tonight!.....![Icon Call](https://www.jaguarforums.com/forum/images/smilies/icon_call.gif)
"how is my car?"
They have taken it to a retro night at uni.
EDIT, thanks Grant, you posted while I was typing.
"how is my car?"
Grant Francis (11-15-2014)
Received 10,916 Likes
The following 2 users liked this post by Doug:
Grant Francis (11-15-2014),
o1xjr (11-15-2014)
You are correct that it is the end of the line that connects to the vapor canister...
It's most accessible by removing the tank, but may be able to be replaced by removing the rear parcel shelf... You'll be able to see where the line attaches to the canister with the parcel shelf off..
I have some photos here that may help...
It'll show where the line comes off the vapor canister and goes through the body, to the filler cap...
Welcome to Jag-lovers - Members Photo Viewing Page
David
Everydayxj.com
David
Everydayxj.com
Just to add a bit...
On the vapor canister, there are three hoses... One that goes to the filler cap, and two that into the boot, and forward (eventually) to the canister in the RHS wheel well...
The ones in the boot are fairly easy to see, the one that goes to the filler cap (in question) is a bit tougher.. It goes through the body of the car, and is nowhere to be seen with the gas tank in place...
If you remove the vapor canister from the C pillar, it may be possible to feed the line back in place through the body... But the easiest way to do it is with the gas tank out...
I did have a car that had water ingress into the tank, because that line was never put back on.. So it's kinda important for it to be there...
Not to mention helping to control the fuel smells...
David
David
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
