fuel caps water drain hole
I usually never leave my S3 under the rain, I always have a 7 layer cover on it, but today I could not avoid the rain. I had to use my S3 because my X300 abandoned me with a faulty spark plug coil.
So I ran a lawn trencher wire into the hole down the pipe just in case it may rain too much tonight. After about 3 feet I could not push the wire further like if there is something obstructing. This on both sides. I do not know if this is normal maybe the channel becomes thinner or it may be clogged ?
On my X300 the write easily goes down until it touch the ground under the car.
Received 10,873 Likes
Take a tall glass of water and slowly pour it into the cavity. If the drain is clear you'll hear water hitting the ground in about 3 seconds.
xjfourty (02-28-2018)
citsalp
01-20-2018 07:37 AM
kalexander
01-30-2017 05:13 PM
