Fuel filter size
Fuel filter size
I put a pre pump filter in long ago. Which I'm now happy I did since it's caught a few pieces of left over rust pieces recently. The problem that hopefully someone can help me with is, the fuel line is 1/2" and I put in the cleanable glass filter that is 5/16". The morons at the auto store couldn't find any filter with 7/16" or 1/2" nipples. I've had to cut pieces off time and time again cause the clamps have to clamp so far down that they cut into it and develop leaks. anyone got a good part number or some type of fix?
I think it's making my pump work hard a bit also since there is a restriction before it, but i guess it's not as big a deal as the clamp cutting the hose.
Received 10,944 Likes
Grant Francis (08-01-2015)
Cannot remember the part number.
Wix make a 1/2" fuel filter. We sell a few at work for the Skyline type guys as pre filters etc.
That small outlet/inlet you have installed will be causing the fuel pump all sorts of grief.
Just googled Summit racing, and they have a GF333 1/2" in/out fuel filter @ $11.97, that is what you need, and change it regularly.
Received 1,236 Likes
i dont care for glass fuel filter housings, i have seen them crack and leak gasoline!
also those early glass filters had a high micron numbers, could/ let small particles of dirt thru and screw up the fuel injectors, carbs can handle larger particles, not so with injectors!
quick thought! if you plugged just one injector,BUT only half plugged would the cylinder run lean compared to the others, engine could,may burn a piston or blow a gasket!
fuel injection engines have different problems relative to carburators.
ever wonder why Jag used , for there F/I engines ,such a large capacity filter? that Ford copied for there engines!
This is the first time since then that I've bought one and really don't like having it. AT ALL!
I hope that NO ONE ever has to go through that.
While a glass filter isn't ideal, its what Jaguar used in the MK2 and it worked fine, there's no pressure in them at all, as it's before any pump, even the MK2 filter had the low pressure pump before it.
You may be forgetting this is just a pre filter, the fact that mightn't filter every micron isn't an issue, because its still doing more than the factory setup, there is still the fuel pump and then a high pressure inline filter.
aholbro1
08-05-2021 05:02 AM
Gerard Radimaker
09-13-2015 10:33 AM
