Fuel Gauge Reads Zero
Hello, got an '87 XJ6 that sat for six months. Just put 5 gallons fresh fuel in each tank.
With power switched on, the fuel gauge needle moves from far left to zero, left or right tank selected. Any ideas? Car runs great, and all selector tank valves are working.
Thanks in advance,
George
Thanks in advance,
George
Received 10,906 Likes
The changeover switch is segmented. One section works the fueling valves. The works the fuel gauge.
Try wiggling the switch, or very slightly pushing it in or pulling out. If the fuel gauge responds then you have a faulty switch, or dirty/loose connections at the rear of the switch, or dirty/weak contacts inside the switch.
If you have non-arthritic fingers you can remove the trip computer and get a finger into the opening and perhaps just reach the connector at the back of the switch. Give it a push and see if the gauge responds. The trip computer just wriggles out of the dash if you can get your finger nails under the edges
XJDanny (09-12-2022)
I jumped the wires behind the switch and got the needle to move. ordered a new switch.
Thanks again,
George
Mkii250 (09-15-2022)
First, thank you for the advice. I jumped power to the terminals on the gauge and got positive movement on both sides. A brand new switch resulted in no change. According to the S57 manual, the only thing left is that both tank sending units must be stuck from sitting for so long. I'll tackle that one in a couple of weeks. Need a break!
While we’re on the subject of fuel, this car has an externally (factory) mounted fuel pump (I replaced it with a new pump last year) and I think the tanks are a little bit too far gone to save. Does anybody have a recommendation for new tanks at a reasonable cost in the U.S.?
An alternative would be to a thorough dousing of the switch with electrical contact cleaner. With the little red straw on the spray can you can find some slots/openings in the switch to direct the spray right to the innards of the thing so it (hopefully) reaches the contacts
davidladewig
06-12-2017 09:14 PM
