Fuel gauge stopped working
Series 3 fuel gauge reading empty (common jaguar problem I know!) But tank is at least 3/4 full. Basically can gauge be removed from dash easily to check connections and where is tank sender unit so I can check both. Then I can isolate the issue hopefully. Cheers JJ.
Received 10,871 Likes
Yes the gauge can be removed. Most remove the speedo (or tach) first and gain access that way.
There is a sending unit in each tank, accessed by removing the tail light
I suggest testing the circuit by grounding the sending unit wire for whichever side is in question. Remove tail light, locate the light green sending unit wire, use a jumper wire to ground/earth the light green wire, turn key 'on'.
The gauge should rise to 'full'. If it does, everything in the circuit is OK and the sending unit must be faulty.
If it doesn't move to 'full' then you can begin checking wires, connections, etc
The following 2 users liked this post by Doug:
jjd (06-13-2016),
Utah Johnny (07-22-2022)
Received 2,399 Likes
JJ:
Lucky us. There are two tanks. Each has it's own sender. Access is through the
tail lights. Fiddly, but doable.
The pump is in the boot, just behind the spare tire. The tank selector valve is there as well.
The tank selection switch is on the fascia. Left in, right out, I think.
That is where I would start my diagnosis. Select tanks. any difference.
Oh, just quizzical. Perhaps the tank is empty!!! Just read an article in "Hot Rod
on fuel gauges. Truck quit running. Guage indicated fuel in the tank. Old fashioned
method. Yard stick belied that!! No gas...
If indeed, your tank is half full and he guage reads empty, the float may have sunk!!
The sensor is a variable rheostat operated by an arm with a float. Similar in a way to a toilet tank valve.
Check and report back. I and/or others will pitch in.
Carl
Carl
jjd (06-13-2016)
jjd (06-13-2016)
