Fuel injector cleaning services
I've used.....
Jaguar Fuel Injector Service
....several times.
Outstanding service.
The owner is David. Great guy.
....several times.
Brutal has recommended these guys in the past they're based in Houston.
Professional Fuel Injector Cleaning Service : Injector Cleaning Service : Injector Cleaning : Clogged injectors : Injector Flow Testing : InjectorRX.com
Brutal (01-30-2012)
My injectors seem to be extremely noisy. I thought it was the tappet guides, but the tappet guides were not loose at all and didn't show any signs of cam damage.
1983 Jaguar XJ6 engine revving under hood - YouTube
Is it possible that a sticky/defective/clogged injector could make this sort of noise? It doesn't seem to get louder or quieter the higher the revs, although the rhythm of it does correspond with the RPMs. It happens the same cold or hot!
It is possible that there also may be a loose tappet guide(s) and while not very common, it does happen on occasion that one or more of the inlet tappet guides may have come loose.
If you plan on removing the injectors for service, it will be interesting to note if there is a change in the 'clicking' sound they make once they're reinstalled.
NBCat
amcdonal86 (03-04-2012)
A second vote for Dave Faircloth.... Jaguar Fuel Injector Service...
One of the best links I've ever seen for the process of breaking down the fuel injectors and explaining the cleaning service:
Jaguar XJ6 SIII injector replacement
Cheers!
David Boger
Everyday XJ
Cheers!
David Boger
Everyday XJ
Re
Thanks Norri for the information as I too belongs to cleaning services and looking for elaborating this in vehicle cleaning services too.
Toronto Cleaning Services
When I had my injectors cleaned due to rusty gas being sucked into the system, David Faircloth was the man I used. The write up David linked was an easy to follow process of removal and installation. Having never worked with injectors on any car let alone a Jag, this process was not only easier than I expected but certainly more cost effective than taking it to an Indy. The car ran so much better afterwards. A highly recommended do it yourself project.
Charlene n John
09-28-2015 07:01 AM
