Fuel Pump Relays - 1978 XJ6
Welcome to the forum kev53,
I've moved your question from UK & Eire Region to XJ6 Series I, II & III forum. Members here with the same model will be able to help.
Welcome to the forum. I have no doubt you will find the enthusiasts here helpful.
That said i dont recall a fuel pump relay on my 76. There is a pair of white wires that come off the tank selector switch run over to small fuel pump located inside of each fuel tank. There also is a saftey inertia switch found on the right hand or US passenger side A pillar that interueps current in the event of a crash. If trippped it can be easily reset.
I just checked the wiring diagram and the white green and white purple wires off the tank selector switch go directly to the fuel pumps. No relay.
kev53 (01-26-2015)
Charlene n John
09-28-2015 06:01 AM
deanh
09-06-2015 08:20 PM
